Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
For Sharon, question about your wheels...
Old Oct 1, 2000 | 12:36 AM
Ben3.2TT@BC's Avatar
Member
Default For Sharon, question about your wheels...
I asked Tempa Mike, he said he is running 5mm spacers to clear the Alcon Type B's with his Fikses. Do you need to run spacers on your Kinesis to clear those Type B's? Thanks.
Old Oct 1, 2000 | 11:34 AM
leslie's Avatar
Elder Member
Default No spacers needed w/ custom wheels like Kinesis
Effectively Kinesis (or other custom wheel manufacturers) will build the spacers into the wheel instead of having the additional part. I was told the spacers on the Fikses weigh several (3?) pounds, so while the Kinesis weigh 20 and the Fikse's ~18, it's possible the Kinesis actually win out (although it's pretty close).
The Alcons are less bulky than the S4's stock calipers, so clearing those is less of an issue (again, the Kinesis's are built to clear the stock calipers if that is what you specify to them). I think w/o the Alcons a 6-7mm spacer is needed to clear the S4's stock caliper.
Sorry to jump in Sharon. Hope this helps Ben.
Tuesday my wheels will arrive (they actually shipped Friday)! I'll post pics as soon as I can... )
Old Oct 1, 2000 | 04:28 PM
S4carl's Avatar
so, what did you finally choose? HRE?
Old Oct 1, 2000 | 09:01 PM
Member
Thanks for the informative reply Leslie. :-)
Old Oct 1, 2000 | 09:02 PM
meem's Avatar
Elder Member
Default 3 pound spacers?! yow!
the 2mm spacers i have on my setup don't even weigh 1/2 a pound -- i can't imagine why the fikse spacers would weigh that much.
Old Oct 1, 2000 | 09:36 PM
leslie's Avatar
Elder Member
Only what I heard, I welcome the people that have them to confirm or deny.
Old Oct 2, 2000 | 08:13 AM
Sharon's Avatar
Senior Member
Default 3lbs?! Certainly not per wheel...
Corey's wheels with the spacers are still lighter than my Kinesis.
Also, Alcon B-Types aren't as wide as the stock S4 calipers. If the wheel clears the stock ones, it'll clear the B-types.
Old Oct 2, 2000 | 08:28 PM
Member
Default So the reason Corey is running with spacers...
is because the Fikses won't clear the B-types? Or is there some other reasons that I am missing?
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 3, 2000 | 11:55 AM
leslie's Avatar
Elder Member
correct, need spacers for S4 stock brakes or B-types. (just different sized ones)
TangoSierra5
Audi A5 / S5 / RS5 (B9)
41
Sep 28, 2017 12:29 PM
4Ring Jelly
Audi allroad
Jun 14, 2009 05:23 PM
anonmartin
May 31, 2006 07:58 AM
ScratchRob13
Apr 2, 2006 07:15 PM
horizontal8
Feb 13, 2006 02:41 PM
