Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Who would be interested in a group buy for S6 Avus wheels?
Old Oct 3, 2000 | 01:21 PM
Ernesto (ERT)'s Avatar
Default Who would be interested in a group buy for S6 Avus wheels?
Looks like another group buy for the S6 Avus wheel's is coming together. Leigh, who put together the previous GP, is putting a list together.
The current timeframe is to begin making concrete arrangements (i.e. prepayments will be necessary) during Q1 of 2001, for delivery thereafter.
Right now, we just need a list of people who are interested, with a number of desired wheels. The cost will range between $300-$400 per wheel, compared to the $600+ if you go through the dealer. The specs are below.
During the last group purchase there were 31 Audi owners who participated.
Here are the specs:
AVUS 17x8 Wheels:
1. ET35, 17"x8" is the factory spec wheel for the 2000 S6 V8. Wheels are not normally available in USA. (Note: the S4tt only comes with measly 7-1/2" x 17" wheels, go figure)
2. Weight of 1 wheel = 26 lbs.
weight of 1 wheel + a 245/40-17 Bridgestone S02 Pole Position = 52 lbs.
3. Clearance for the Mov'It Big Red 993tt calipers/rotors is superb. 2 fingers clearance to the inside of the spokes and 1 finger clearance to
inside diameter of wheel. There is no better wheel for clearance.
4. Made by SpeedLine for Audi. Made in Italy. Genuine AVUS style, which has the dimpled and flared spoke ends x 6 spokes.
3. Metallic silver finish, Clearcoat is deep, beautiful
6. Plastic center cap is very nice. Same as the S4tt's center caps.
7. Minimum tire is 245/40-17. 255's are OK for at least some tires and are the OEM spec tire size. Do not use 235 or smaller!
If interested, shoot me an email to ertey@yahoo.com (hit my name at the top of the post). This is only a preliminary list, gauging interested from the AudiWorld community. No guarantees that it will go through.
At this time there is no set closing date. A distribution list will be created, so as information becomes available it will be easy to send it out. Also, when things begin to firm up in Q1/2001, additional postings will be made.
Cheers,
Ernesto
Old Oct 4, 2000 | 12:50 PM
tompa's Avatar
New Member
If you can get 18" AVUS S8 wheels, I think you'll get some S4 owners to upgrade
Old Oct 7, 2000 | 10:57 AM
footloose's Avatar
New Member
Default Actually I already investigated 18" Avus S8 for the A4 and the offset is wrong, it would stick out.
This would be same problem w/S4 as well, which has same wheel specs as A4. If you were willing to get your fenders rolled (sounds like a REAL PIA)then you could probably make them work. They would be sweet, albeit VERY heavy.
If the Avus 17"s are heavy, I'd hate to think about the 18"s.
quattroluvr
May 22, 2001 10:08 PM
DougG_2.7T
13
Jan 18, 2001 09:15 AM
Ernesto (ERT)
Oct 3, 2000 06:02 PM
Ernesto (ERT)
Oct 2, 2000 10:23 PM
