Questions... please help...
Thanks all.. I did a search in the archives and to no avail.. sorry if this sound repetitive.
Any comments Eddie?
Regards,
HN
There are people running 18" MGRs here - I've asked them to post pictures but have not seen any.
Reggie
98.5 2.8QMS
Go to the tirerack website for a good description.
Link below.
I also used Discount Tire - They were quite good but had trouble getting the correct hubcentric rings and also the correct lug bolts (My MGRs took a longer bolt than stock and they had to special order some that also took the same size lug wrech socket - so that I could use the stock lug wrench that came with the car.)
You do not want 215s on the wheel. The wheel rim will be wider than the tire and make it easier to scrap the rim.
Good Luck - You might be able to get more response tomorrow
Reggie
98.5 2.8QMS<ul><li><a href="http://www.tirerack.com/wheels/tech/offset.htm">Offset info</a></li></ul>
