Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Camber Kits necessary for 18" and 1-1.5 drop?
Old Oct 11, 2000 | 10:06 AM
hardNock's Avatar
New Member
Default Camber Kits necessary for 18" and 1-1.5 drop?
Ok,
I've read tons of posts on coilover setups and race springs but you guys never mention anything about camber kits (from what i've read anyways =P).
So what's the deal? I know it's important even a 1-3 degree change. So do they make camber kits for audis? Should I be concerned about this? I am thinkin about getting the HR coilovers.
Thanks Guys,
Dave
Old Oct 11, 2000 | 12:15 PM
eharleq's Avatar
Junior Member
Default Camber Kits necessary for any performance...
Sure, I've mentioned it a dozen times in the past month (Racing and Perf. Forums). The Audi chassis, with even serious drops, needs much more camber for any kind of handling. I haven't tried the new kits (adj arm.), under warranty.
The problem is even more worse with wider tires/rims.
I've never lived any place that could safely run more than 16" without bending a rim.
Old Oct 11, 2000 | 10:28 PM
Chard's Avatar
Default uggh, hate to see your roads (more)
as far as i know, a camber kit isn't necessary for lowering your a4. this is what i've been hearing on the forums for some time now. it's not even necessary to get an alignment, they say. i've heard the explaination for this is because the A4 id built to keep the tires flat on the ground no matter what height the car is at. You might want to double check this info, because i'm not sure. just regergitating it...hth.
Old Oct 12, 2000 | 03:41 AM
SIR VBall's Avatar
You definitely still need an alignment.
Old Oct 12, 2000 | 06:12 AM
RobeyTTQ's Avatar
New Member
Default K-Mac Suspensions has kits for the A4's etc.
Call Jeff Owen, Manager at K-Mac in Orange CA. 714-682-9555<ul><li><a href="http://www.k-mac.com">http://www.k-mac.com</a</li></ul>
Old Oct 12, 2000 | 09:19 AM
eharleq's Avatar
Junior Member
Default Camber kit needed, regardless of lowering...
The dual, split a-arm design is very innovative, and the camber change in a corner is much flatter than the mac-strut design. But the issue is the net camber is far too low for real cornering.
Tomasz@Startup
Motorsport Discussion
20
Apr 16, 2004 06:57 AM
cordaroy
Dec 19, 2003 11:14 AM
yellowTT
Nov 8, 2002 03:54 PM
shorki_07
Apr 6, 2001 12:11 PM
AQE
Mar 20, 2000 07:08 AM
