Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Winter Tire Questions...
Old Oct 16, 2000 | 08:59 AM
mm's Avatar
mm
Default Winter Tire Questions...
...I'm looking to get some good high performance winter tires for the S4 Avant I have on order. I have a set of Michelin Pilot Alpins on order in a 205/55 R-16, but now I'm wondering if I would not be better off with either the Pirelli 210 Snow Sports or the Blizzack LM-22s (although I'm not really fond of Bridgestone Tires for some reason).
The tires will be for winter use around the Seattle area, so they will see lots of wet and dry use, with weekend runs up to the mountains for skiing where there will be plenty of snow, ice, and slush. Any thoughts on how these three tires compare to one another?
Eddie recommends the LM-22 quite highly, even over the Pirelli and Michelins, but I'm just a little leary of Bridgestones.
Old Oct 16, 2000 | 09:11 AM
CraigB's Avatar
AudiWorld Expert
Default I have the LM-22s...
I did a little wet driving already and they handle great for a winter tire. Even on dry pavement they are not really a compromise at all. I'll post snow driving impressions when we get some.
Old Oct 16, 2000 | 10:19 AM
Eddie@Tirerack's Avatar
Member
Default You know what I think
<i>(although I'm
not really fond of Bridgestone Tires for some reason). </i>
Really no valid reason for you thought on that. Bridgestone has long had the winter tire technology to beat, and this latet version is no exception (having driven on them on our slide & drive last week).
Let me know what you think!
Thanks
Eddie
Old Oct 16, 2000 | 02:41 PM
Donnie's Avatar
New Member
Default Pirelli 210's ..
I'll have these on in about a week (205-50-17's).
IMHO Hakka 1's are the best, when/if you can find them. I will keep you posted.
Donnie
PDX Area
Old Oct 16, 2000 | 04:42 PM
Hans's Avatar
Member
No problems w/ my Pilot Alpins last winter (205/55/16).
Old Oct 17, 2000 | 09:56 AM
WagonBoy's Avatar
Default I got the new 210 SnowSports for my S4 Avant...
I've been running the previous version of the 210 for three CO winters now. They are very good. The new ones have a different tread patter, but are supposed to be better....time will tell.
Last year I used a 205/50/17 mounted on the stock S4 wheels. This size worked great, but left a lot of rim exposed. I nicked them more then once just on pavement changes. This year I went with the stock size, 225/45/17. It might not be AS good in heavy snow/slush, but the size should work much better in the dry and just as good on hard pack.
As for other tires. The Michelins should be right on par with the Pirellis. I don't know much about the LM-22s. I stayed away only because in the past Bridgestone winter tires have worn out too quickly. We're 80% dry in the winter here in Denver, so I want a tire that can handle in the dry and won't burn up when the roads dry out. The LM-22s are supposed to be much better though...
Hope this helps,
Rick
98.5 Avant QMS
01 S4 Avant on order
Old Oct 21, 2000 | 11:09 AM
MAXFX's Avatar
New Member
Default Since you're in Seattle, go to Costco & look at BFG Winter Slaloms
They are snowflake rated, manufactured by Michelin, (BFG doesn't manufacture any tires Michelin owns the BFGoodrich brand name).
They are new tires on the market, being out for (I think) one year.
I used four on my 1999.5 TQMS last year here in Alaska and was happy. Will be putting them on again in another month.
If you do a search for BFG Winter Slaloms in both the Tire and A4 forums you'll find detailed comments from me on the tires.
tsmitty
Pacific Northwest Discussion
Jan 5, 2016 01:40 PM
billbob
Sep 28, 2001 08:23 AM
prm
Dec 4, 2000 03:00 PM
Toshio
14
Oct 19, 2000 10:50 AM
KDL
Aug 25, 2000 06:07 AM
