Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Will 205/50-17 tires work on the stock S4 rims?
Old Oct 18, 2000 | 08:52 AM
dbex's Avatar
Default Will 205/50-17 tires work on the stock S4 rims?
I know I'll be sacrificing a little protection of the rim lip, but I figure a slightly narrower tire will be better for snow tires (and maybe a little easier to find). Will the 205/50-17s be the same basic rolling radius as the stock 225-45-17s?
Thanks,
Dave
'01 S4, Santorin/Silver
Old Oct 18, 2000 | 10:25 AM
Jenner's Avatar
Default I just got Dunlop Winter Sport M2's in 205/50/17 for my stock TT 6 spoke 17" rims
They will be mounted on Friday. It will make your speedometer 0.04% off(not even noticable). If the rims are 17"X7.5"(like the TT stock rims) you should be all set.
Lets you use your stock rims and clear the big brakes, but with 205 get the bite of a 16" tire setup.
If you have any questions I can give you more feedback on the setup after this Friday. HTH!
Old Oct 18, 2000 | 11:35 AM
WagonBoy's Avatar
Yep, they work well. I used them last winter on my S4. Watch the curbs and pavement changes!
Old Oct 19, 2000 | 04:19 AM
Eddie@Tirerack's Avatar
Member
Default Yes, but..
The diameter is a really good match for the OEM size,, BUT not very common at all, so there are just a few offerings in that size.
You are correct about the narrower contact area, which I do recommend if you are actually driving on something other than dry pavement most of the time, as there is a handling & cornering tradeoff as well.
Feel free to call me to discuss your options furhter, or when you are ready!
Thanks!
Eddie
<i>I know I'll be sacrificing a little protection of the rim lip, but I figure a slightly narrower tire will be better for snow tires (and maybe
a little easier to find).</i>
Ghostfire
10
Mar 15, 2004 02:23 PM
sledhead
Motorsport Discussion
12
Jan 23, 2002 01:50 AM
Anthony
Jan 23, 2000 02:10 PM
Daniel L.
May 21, 1999 08:35 AM
