Question for fellow Vredestein Wintrac owners
However, unlike most asymmetric tires, it also seems to have a "right" and a "left" -- the V-shaped tread pattern is off-center on the tire.
With the installation they put on my car, the "V" is biased towards the same side on both sides of the car. In other words, there is no difference between the left and right tires -- they're both off-center towards the right side of the car.
Intuitively, I'd expect there to be different left and right tires, so the V would be towards the inside or outside of the car on both sides, instead of just biased towards the right side.
Any thoughts? Are your tires set up like this too?
Dan
If yes, then look at the other side of the car...nothing there? Take the wheel off the car, and look at the back of the tire. You may just find that your intuitions are correct. :-(
