Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Lowering Springs and Front Alignment Problems
Old Dec 11, 2000 | 07:30 PM
orttauq's Avatar
Default Lowering Springs and Front Alignment Problems
Cross Post From Performance:
I am planning on getting the Eibach Pro Kit Springs for my A4Q sport but was just advised that the front can NOT be brought back into alignment resulting in worn tires and bad handling.
I have not found anything on the Forum about this problem. Please adivise if you have done this mod.
TIA
Old Dec 11, 2000 | 08:32 PM
Catfish's Avatar
Junior Member
I've got Eibach/Bilstien, 18' wheels, alignment done at dealer, no problems.
Old Dec 12, 2000 | 06:10 AM
Howard L.'s Avatar
New Member
Re: Where did you get your Bilsteins? I thought they are still working on them.....
Old Dec 12, 2000 | 06:11 AM
Dan F.'s Avatar
Junior Member
Default I haven't had a problem either.
The Eibach springs are identical to the OEM sport springs ("Eurosports") used in some markets. Therefore, I don't think using them should cause irreparable harm to your car.
The camber increases slightly when you lower the car; this could cause more uneven wear on the tires. Maybe this is what your source meant.
Dan
Old Dec 12, 2000 | 06:15 AM
eharleq's Avatar
Junior Member
Default 2 issues. Yes, more camber from the drop will...
make the tires last longer and improve handling, the factory base numbers are FAR too conservative. Yes, your tech is a moron. What he is really saying is that he is too damn lazy to move the subframe to center it.
Old Dec 12, 2000 | 11:03 AM
Catfish's Avatar
Junior Member
PES
Old Dec 15, 2000 | 10:04 AM
ajp's Avatar
ajp
Default my car is lowered 50mm with the neuspeed race and the alignment was only barely off...
after lowering. I've had the setup for 20k with no unusual wear etc...this setup is 30mm lower than what you're looking at. I agree goto a different tech...
alex
olopez a6 c5
Jul 10, 2017 05:18 PM
matt boshar
Apr 19, 2003 07:44 PM
?lueshirt
Jul 7, 2001 12:57 PM
orttauq
Performance and Tuning
Dec 14, 2000 11:14 AM
chris T.
Sep 23, 1999 06:41 AM
