Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Blizzak WS15 on A4- What Pressure?
Old Dec 20, 2000 | 10:01 PM
jimho's Avatar
Default Blizzak WS15 on A4- What Pressure?
What are folks using for pressure with 15" WS-15's on an A4? The sticker on the fuel filler door says 35lbs when loaded with 4 people, but the max on the tire says 32psi... When I had the snows put on last week, the guy who checked the pressure refused to fill it to 35 as per my request....
How high can you go?
Old Dec 21, 2000 | 07:41 AM
unA4dable's Avatar
New Member
And while you're at it, what pressure for Hakka Q's 205/55R16 on A4? Thanks!
Old Dec 21, 2000 | 08:31 AM
DMoore's Avatar
Default Look inside your gas tank door
Tire pressures should be listed there, and A4 shows tire pressures for that size tire. (At least, both of my previous A4's had that info.) It even give you an idea of how much more air pressure to run if you're driving the car heavily loaded.
Old Dec 21, 2000 | 08:39 AM
unA4dable's Avatar
New Member
OK, thanks; wasn't sure if there was a reason to use different pressure for snows.
Old Dec 21, 2000 | 06:12 PM
Andy Hedin's Avatar
My A4 owner's manual recommends running higher pressure with snow's...3-5 psi more, if memory serves
Old Dec 21, 2000 | 07:32 PM
jimho's Avatar
Default Re: Look inside your gas tank door
Thanks...Now we have an interesting problem...in the original message I said the fuel filler door says 35psi. The tire says inflate to 32psi MAX. Andy Thinks the manual says 3-5psi over the fuel filler door (or 5 or 6 lbs over the recommendation on the tire sidewall) .....
They can't all be right.
Old Dec 22, 2000 | 05:56 PM
DMoore's Avatar
Default I vote for tire mfr.
If the tire manufacturer says "don't inflate over X psi" I'd believe them. If that's the max safe pressure, then that's as far as you should go. Maximum pressures on tire sidewalls aren't inflation recommendations, they're MAXIMUM pressures. They shouldn't be exceeded. So in this case, I'd say pump 'em up to the tire max. and quit there. If they drive OK, fine. If not, the solution isn't more air pressure - it's different tires.
My $.02.
DMoore
'00 S4
DSMLVNV
A4 (B9 Platform) Discussion
34
Sep 2, 2019 07:43 AM
acadia1
Nov 15, 2008 08:14 AM
JoshLan
Apr 15, 2007 08:22 PM
John
Oct 30, 1998 06:18 AM
