New snow tires (problem)
'00 2.7T
Ming/Sports susp
6sps
Also, Tirerack recommends retorquing the lug bolts after 75-100 miles of use (90 ft-lbs for an A6). I found that a couple of my lug bolts had slightly loosened during the 75-100 mile period. Maybe that is the source of the vibration.
I'm am running the same tires and have had no vibration problems. Mine are mounted on ATP S5 rims and were superbly balanced by Tirerack. They are a truly first-class outfit!
Finally, are the lug bolts suitable for the seats on the wheels? Tirerack ships matching lugs bolts with their wheels to ensure best fit.
Good Luck and Happy Holidays!
was not the wheel/tire package...I was asked if I wanted my weights on the inside and I said no since I will change OEM wheels once the Dunlop sp9000 wear out.
Thanks for tip on the 90 lbs torque. I'll ask about that when they "rebalance" the wheel. If its out of round I am sure Tirerack will send new ones.
'00 2.7T
sports psk, suspension
6sps
Reggie
98.5 2.8QMS
