Does my speedometer need adjusted if I increase my rim size? if so, how?
For instance, stock A4 tire size is 205-55-16.
Going to a 17" wheel, you would use a 225-45-17 tire (which I believe is within +-1% of the rolling diameter of the stock tire).
Sidewall height is 205mm * 0.55 = 112.75mm (16's)
vs. 225mm * 0.45 = 101.25mm (17's)
Now if you get a tire size that does not maintain the rolling diameter of the tire, your speedo will be affected.
