Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Is it safe to use a 10 millimeter spacer? If so which is the best brand to buy and how much $
Old Jan 25, 2002 | 08:20 AM
audious's Avatar
New Member
Old Jan 25, 2002 | 08:57 AM
A6 2.7T 6 Speed's Avatar
Default Re: Is it safe to use a 10 millimeter spacer? If so which is the best brand to buy and how much $
I have a 10 mm PowerTech spacer on the rear of my A6 2.7T. You will need longer bolts. Properly torqued there should be no problem. PowerTech and H&R are both made very similiar and are good brands..
Old Jan 25, 2002 | 09:01 AM
audious's Avatar
New Member
How much were the longer bolts? I am using them for a 19" Radius S4 wheel
Old Jan 25, 2002 | 09:14 AM
Default They ideally need to be 10mm longer ....
than stock; about 40mm.
Which Radius wheel do you have? I have 18 inch R6's.
Old Jan 25, 2002 | 09:20 AM
audious's Avatar
New Member
Default Where can I find them and how much did you pay? I have the 19" S4 wheel
It is the 2 piece wheel, I believe they are called the RD sport? you can see the wheel if you go to www.Supremepowerparts.com they are in there wheel section.
Old Jan 25, 2002 | 11:54 AM
CraigB's Avatar
AudiWorld Expert
Default I have 10mm MTM spacers...
I bought them used from S4TNT. They are $270 new (set of 4), which includes the longer bolts.
<img src="http://pictureposter.audiworld.com/25/s4_122501d.jpg"><ul><li><a href="http://www.hoppenmotorsport.com/spacers.htm">Hoppen Motorsport - MTM wheel spacers</a></li></ul>
QuattroFan02
Jun 21, 2007 07:14 AM
.aye four.
Oct 19, 2005 02:19 PM
MarkConrad
May 16, 2004 03:32 PM
Juggernaut
Sep 16, 2002 05:56 PM
got_root?
Aug 20, 2002 04:02 AM
