Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
S4 Camber specs = worn inner tread on front??
Old Jan 28, 2002 | 12:37 PM
AbnormallyAspirated's Avatar
Default S4 Camber specs = worn inner tread on front??
My fronts with 11K miles are worn to no depth on the innermost tread, but not bad on 7/8 of the tire. Rears are fine.
The tires were probably NOT rotated ever since new (long story, sordid history)
Would this be normal under the circumstances given the significant negative camber spec, or is it indicative of an alignment problem?
Informed opinions preferred.
Old Jan 28, 2002 | 12:46 PM
Sharon's Avatar
Senior Member
Default unless you've got some trick upper links
you don't have "significant" negative camber issues IMHO. The S4 doesn't have adjustments for camber and even if you dropped the ride height, you're still not going to be more than 1.25 (+/- .25) degree negative.
Check your toe settings. Too much toe-out will cause inside tire wear.
And, <insert wagging finger here> rotate your tires more frequently.
kholland
Dec 27, 2009 08:31 PM
SAF
RS 6 Discussion (C5)
21
Sep 13, 2007 01:36 PM
einnod17
Feb 3, 2007 07:14 AM
SinChar
11
Apr 7, 2003 01:19 PM
Willthrill0
Audi allroad
Jan 6, 2003 01:46 PM
