problem with alignment and excessive tire wear
i got new pirellis with only 8,000 miles on them, and the insides of my front tires are worn down twice as much as the outsides - the tread-ware indicator is around 50%. this is ridiculous. i even took it in around 4000 for an alignment check and everything was way, way off. this car eats through tires at an insane rate. what could possibly the problem? maybe the alignment guy has the wrong settings? well, at least the tires are under warranty because i will probably need some new ones in about 8,000 miles. does anybody else have this problem?
just the front 2 tires on the insides - 151500 miles.
what do i need to do to determine what is causing the problem?
i took the car out and got it up to 90 today. i felt slight vibration on the wheel at 60 and it seemed to increase some as i went faster. you told me to jack up the car and feel for slop when shaking the wheels - can you describe this process in more detail - what exactly is slop? like i said, it's my front tires - they are halfway gone (probably more) on the insides after only 9 months and 8,000 miles. the backs are in better condition -but i had previosuly had problems with rear tires. i really need to get this fixed now before my tires are completely shot (again). 4 new tires per year is not resonable. but first i need to know what the problem is.
thanks,
matt
Are you using the same shop for alignment each time? Most alignment shops will quickly identify worn parts in the suspension because doing an alignment and checking it becomes impossible (suspension never returns to the same values). Did they point out anything about worn out joints? It somehow sounds like you have worn ball joints.
High inside edge tirewear is usually because the combo of negative camber and toe-in is too high for your type driving.
In the US most roads are crowned in the middle for water runoff so steering slightly left to go straight is normal.
Jacking up a car and wiggling the tire is not the way to check for worn parts (except wheel bearings). When the angle on a worn joint is changed a lot, like when the vehicle is jacked up and everything is fully extended, in many cases the joints feel fine because they are not positioned in the worn area. I had an old van that used to pass state safety inspection, including a similar "test" of the suspension even though the joints were severly worn, for just this reason.
Before:
LF: (camber: -1.18 caster: ... Toe: -.18*)
RF: (camber: -.86 caster: ... Toe: .60*)
Total Toe Front: .42*
LR: (camber: -1.16 Toe: .64*)
RR: (camber: -1.23 Toe: .50*)
Total Toe Rear: 1.13*
* means the value is out of the specified range
After:
LF: (camber: -1.17 caster: ... Toe: .04)
RF: (camber: -.84 caster: ... Toe: .09)
Total Toe Front: .13
LR: (camber: -1.13 Toe: .15)
RR: (camber: -1.21 Toe: .14)
Total Toe Rear: .29
i also just noticed something on the top of the printout it says "Audi: 80/90 Quattro : 1990-91 : except Model 90 20 Valve" - but I have a 20 Valve!.
yes i've used the same alignment place each time (NTB). they haven't said anything about any parts of the suspension and everything was checked off from the one in april.
the problem with the steering is more that a slight turn to the left, i'd estimate maybe 10-15 degrees to the left to keep it straight, and i notice it on non-crowned roads also.
thanks for any help,
matt
One more thing. I dont know the earlier Audi at all but if the front camber can be balanced (L=R) it ought to be closer than that. The contact patches will be different and adding a driver will just make them more different. That can contribute to odd straight line behavior like you describe.
