Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Ideal width and offset for an S4?
Old Feb 9, 2002 | 12:11 PM
gr's Avatar
gr
Member
Default Ideal width and offset for an S4?
Sorry if I should be able to find this answer in the archives, I've been looking for almost an hour!
I am thinking of having some wheels custom made for my car. I definately want 18"ers. What is the ideal width and offset for an S4?
Is wider better? i.e. should I try to get an 8.5" or 8" or stick with a 7.5"
The right offset would depend on the width, right?
Can anyone help?
Thanks in advance!
Old Feb 10, 2002 | 07:51 AM
kennyc's Avatar
Default The stock rim is 17X7.5 ET 45 so if you want to go 8" wide wheel you need ET 35.
I do not recommend you go to 8.5. I found a lot of rubbing issues with that size. You need to roll the fender if you want to go that wide.
Old Feb 10, 2002 | 11:39 AM
gr's Avatar
gr
Member
Default Thanks! I figured from reading that 8.0 was the most reasonable size. If I could only get them in
a 7.5" should I stick with the stock ET 45 offset? I guess that would make sense since the diamater really doesn't have much to do with the width, right?
Thanks for the answer!
Old Feb 11, 2002 | 09:45 AM
Eddie@Tirerack's Avatar
Member
Default Re: Ideal for an S4?
There isnt really an 'ideal' spec that itr nees to be. Most aftermarket wheel run a bit wider 8" typical, which also requires a lower offset as you go wider, so *most* wheels will usually be about a 35mm offset for the best on car fit.
Hope this helps. Call me with any questions, or if you need to order!
Old Feb 12, 2002 | 08:50 PM
kennyc's Avatar
you are correct. The offset is only related to the width of the wheel.
Yoshimura
Q5/SQ5 MKI (8R) Discussion
10
May 21, 2012 09:02 PM
01blackS4
Feb 4, 2002 04:10 AM
siberian
Oct 19, 2000 09:08 AM
