Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
S4 Wheels or A8 Wheels for my A4, what would you do?
Old Feb 14, 2002 | 09:55 AM
brian1's Avatar
New Member
Default S4 Wheels or A8 Wheels for my A4, what would you do?
Which set should I use. I know the Avus wheels are heavyier and I know the A8 wheels are a little wide. I'm inclined to go with the S4 wheels but I can't make up my mind. Opinions?
Old Feb 14, 2002 | 02:16 PM
kennyc's Avatar
Default A8 wheels need spacers... I did not know it until I got a set!
Spacers cost around $240 extra. You need to factor that into your consideration.
Old Feb 14, 2002 | 09:02 PM
A4SOME's Avatar
Default Go with the S4 Wheels!
If you want to go wider than consider using the H&R wheel spacer 15mm. That's the setup I going with next. Then either the Intrax cup kit or the Eibach Prokit with Pro-dampers. Just my opinion.
Muzu
20
Mar 17, 2016 09:09 PM
athensga
Mar 29, 2012 11:20 AM
djillusion
16
Dec 25, 2006 05:30 AM
bostoned
Apr 20, 2005 01:19 PM
ploglet
Audi allroad
Mar 10, 2002 11:25 AM
