Eddie@TireRack, Will the Mille Miglia 18x8.5 Cup3S fit my A4?
The damping on the Konis are adjustable. How stiff should i set them in order for the 8.5" width to clear w/o rubbing?
Im also considering the 18" OZ Superleggera, will they clear?
btw, how much does the MM 3S weigh?
Thanks
You will want to use them with a 225/40R18 tire for the proper fitment, esp if car is lowered with the more agressive H&Rs.
Damping, you will want to fine tune to your own preferences. I typically find a midrange setting best for daily driving, but you can fine tune to your liking.
18" OZs will fit as welkl. The Cup3s show a 30lb wt in the 18" size, so if you are concerned about weight for track use, then I suggest the OZs as your better choice there- give me a call if you would like to discuss further!
