Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
17 x 7.5 vs 17 x 8, which is better and why?
Old May 10, 2002 | 08:29 AM
robby's Avatar
Old May 10, 2002 | 08:43 AM
MikekiM@PureMS's Avatar
Former Vendor
Default Depends..
a 7.5 will result in a slightly taller sidewall, meaning more protection. A 8 will result in a slightly shorter sidewall meaning slightly better traction. Will you notice? I doubt it.
Will it looks much different? I doubt it.
Old May 10, 2002 | 09:36 AM
Ted K's Avatar
Default Disagree entirely on "...will you notice it..." (more)
I use the stock Avus wheels (17x7.5") in the winter, and have wider BBS (17x8") the rest of the year. The BBS look significantly more aggressive. This is because with the wider wheel, the outside edge of the tire/wheel is now flush with the fender, rather than being tucked under it. Also, by going 1/2" wider, the tire is more squared off where it meats the bead of the wheel rather than rolling back in. I think that it will improve performance as it gives you a slightly wider contact patch, but that is probably not noticeable. I think asthetically is where it makes a big difference.
mtnbikerva1
Q5/SQ5 MKI (8R) Discussion
9
Jan 5, 2014 06:30 PM
ColoQuattro
Jul 16, 2007 05:41 AM
robby
May 10, 2002 04:07 PM
Speeder Sam
Aug 30, 2001 09:41 AM
DD
13
Feb 15, 2000 09:20 PM
