Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Tire pressure for Bridgestone S-03's - 235/45R17???
Old May 11, 2002 | 08:24 AM
stlthXLR8R's Avatar
Default Tire pressure for Bridgestone S-03's - 235/45R17???
Just got my Oettinger 17X8 wheels and S-03's!! What a difference!!!!!! And the car looks fantastic!
My car (01 2.7T non-sport) came with OEM 215/55R16's. Door jam on car only states PSI for 16 inch wheels. Presently running 40 all around and the ride is definitely a bit harsher BUT AMAZING!!
I know trial & error is probably going to be the rule, but where do I start???
Thanks!
Old May 12, 2002 | 12:43 PM
TXurS6's Avatar
Default I'm running 40/front and 38/rear...
I have the S-03's on 17X8 O.Z. Superleggeras. Compensates a little for the natural understeer and makes the car a little more neutral.
Try the link for a handy way to determine the best pressure for your style of driving.<ul><li><a href="https://forums.audiworld.com/a6/msgs/53203.phtml">https://forums.audiworld.com/a6/msgs/53203.phtml</a</li></ul>
Old May 13, 2002 | 12:08 PM
stlthXLR8R's Avatar
Thanks for info - I'll let you know where I end up!
Old May 15, 2002 | 10:49 AM
stlthXLR8R's Avatar
Default Update....
Have been running 40 front and 38 rear for last 3 days and I must say these tires are fantastic. Dry handling is almost scary - havent found cars limit on cloverleafs... Rained in CT recently and wet handling is also great. Only issue is tire wear on S-03s - dealer said about 20-25K depending on driving style. Ive only got 450 miles on them now, and figure they are still breaking in....highly recommend S-03s!!!
Old May 15, 2002 | 02:01 PM
TXurS6's Avatar
Default Great...
I've found that the car/tire limit is now greater than mine. I guess that's a good thing =8^)
Has it hit 80 deg yet? If it hasn't, you'll notice even more 'stick' when it does.
On the life of the S-03's, "If You Play, You Pay".
Old May 18, 2002 | 06:01 PM
stlthXLR8R's Avatar
Default Re: Great...
Jim - you are right about the warmer temps - was over 80 in Connecticut yesterday and I took the car out for a spin. WOW! (and they're not even broken in yet....)
Life is good...
dougs2.7T
9
May 10, 2003 04:11 PM
BlackA6
Oct 23, 2002 04:02 PM
kensS4
Aug 1, 2002 11:20 AM
PsychoS4
9
Jul 24, 2002 04:22 AM
CactuSavant
15
Jul 5, 2001 06:19 AM
