Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
BF Goodrich G Force KDWS from TR.....
Old May 13, 2002 | 01:10 PM
CEB's Avatar
CEB
Default BF Goodrich G Force KDWS from TR.....
I bought a set of these from TR in the 235/45/17 size for a set S4 Avus rims to put on my 2002 A6 Avant.
Which side of the tire goes out (I don't see a "this side out" on the tire)? I see a brown stripe around one side of the tire and the opposing edge has an irregular groove on the outside.
Also - any ideas about tire pressure - the TR rep suggested whatever was on the doorsticker - but the door sticker (actually gas cap sticker) is for the stock 16's.....
Old May 14, 2002 | 07:06 AM
4kq's Avatar
4kq
Member
The more siped side goes on the inside. Bigger blocks on outside.
Old May 14, 2002 | 10:27 AM
Eddie@Tirerack's Avatar
Member
Default Re: BF Goodrich G Force KDWS from TR.....
The tire should be listing 'side facing out' since they are an asymmetrical tire. If not, the larger blocks would be mounted to the outside edge of the wheel, as a reference.
Tire pressures.. You can fine tune to your liking, but basically since you moved up in side- set to OEM spec 16" pressures, and add 1-2 psi on top of that, that should get you pretty ideal to where you want to be (or at least a base reference)
Hope this helps!
Old May 15, 2002 | 06:28 AM
CEB's Avatar
CEB
Thanks to both of you
nemesisa6
NY / NJ / CT Discussion
Mar 22, 2008 07:38 AM
s4LEX
Rocky Mountain Discussion
Mar 20, 2008 04:56 PM
red69mako
Mar 11, 2007 08:52 AM
AForePlayin'03
Aug 16, 2005 09:52 AM
al
Jan 20, 2000 09:22 AM
