Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Whats safest way to clean BBS CH rims? Thanks
Old May 16, 2002 | 07:20 AM
bitrbo_in_mass's Avatar
Junior Member
Old May 16, 2002 | 08:08 AM
Ted K's Avatar
Default I generally wax them at least every other time I wax the car...
That will help to prevent brake dust from sticking. Then, on a weekly basis, after I wash the car, I spray them down with One Grand Show Off detailing spray and wipe them with a 100% cotton terry cloth rag. If the car is clean, but the wheels are dirty and I want to clean them without washing the car, I also just spray them down with One Grand Show Off and the dust wipes right off. Just don't do it if the wheels are hot.
I have BBS wheels also, and this should keep them sparkling clean. Hope this helps.
Old May 16, 2002 | 06:17 PM
John P. (TT 225)'s Avatar
Default P21S Wheel Cleaner is pH-neutral. I'd use this before a slick
detail spray, as you don't want that stuff on your rotors/pads.
Old May 16, 2002 | 10:14 PM
A4lien's Avatar
Junior Member
Call Larry at Carcareonline.com for suggestions. I love the P21S wheel cleaner.
Old May 17, 2002 | 06:04 AM
Ted K's Avatar
Default Who said about getting it on the rotor pads. You'd have to be real sloppy to do that...
The wheels are painted, so this is a real great way to clean them, and keep them shiny without stripping the wax. P21S Wheel cleaner, while ph neutral, will completely strip the wax off. Unless you plan on waxing them every week, I'd only use this when you're doing a major detailing or when they're very dirty.
Old May 20, 2002 | 09:37 AM
Eddie@Tirerack's Avatar
Member
Default Cleaning any wheels..
<ul><li><a href="http://www.tirerack.com/wheels/tech/finish.htm">Cleaning/Finishes 101</a></li></ul>
Old May 21, 2002 | 02:10 PM
UberVier's Avatar
Default I use a soft wash mitt like the one I use on the paint, and I use fresh new soapy water (car wash).
Also waxing is very nice for the CH's. I also make a point to run the mit around the inside of the wheel and get all that grime off too. It makes everything look so much better than just cleaning the painted surface.
90v8quattro
Jul 14, 2007 06:57 PM
oc_tt
Auto Detailing Discussion
Jul 1, 2007 12:31 PM
jjd
25
Apr 3, 2006 06:14 PM
volman
Sep 23, 2004 10:23 PM
mike27t
10
Jun 6, 2003 06:59 PM
