Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Xpost: Can someone please explain wheel technolgies
Old May 29, 2002 | 01:41 PM
Man Of Many Parts's Avatar
Junior Member
Default Xpost: Can someone please explain wheel technolgies
Differences in weight, strength, 1pc vs multi pc, cast vs forged etc.....
Old May 29, 2002 | 02:11 PM
PeteH's Avatar
Default Here's a go at it (basic stuff)....
Cast wheels: are almost always one-piece wheels of cast aluminum. Some multi-piece wheels have cast center sections. This is the least expnesive method of making wheels. There are different kinds of casting methods, but for the most part they all involve heating a block of aluminum to a liquid state and pouring that into a mold. Cast wheels vary greatly in their strength and weight, dependent mostly on the manufacturer and its technology.
Forged wheels: a block of aluminum is placed in a press and pressure is applied to the block to make the desired wheel shape. CNC machines do the final detail work. Most all multi-piece wheels have forged center sections while the rims or rim-halves (3-piece wheels) are of spun aluminum. About the only variation of forging is SSR's proprietary Semi-Solid Forging which involves heating the block to a buttery consistency before forging.
One-piece wheels are just that... one piece. Two-piece wheels have a center section attached to a one-piece rim. These can be welded, riveted or bolted. Three-piece wheels have a center section attached to two separate rim-halves. These are then riveted or bolted together with a bead of silicone to seal the rim-halves.
Forged wheels are typically stronger and lighter than cast, but you pay for that feature. Multi-piece wheels have the advantage that you can replace a bent rim without replacing the entire wheel. Examples of forged wheels are Kinesis, Fikse, Forgeline, HRE.
Cast wheels tend to be heavier and less strong than forged wheels, but they are typically less expensive. Quality varies widely among cast wheels, as does weight and cost. Examples of cast wheels include BBS, ACE, Ronal, OZ, Borbet some Speedlines, and just about anything at Tirerack (but not SSR).
Hope that helps.
The Tirerack link has a little more detail.
PeteH<ul><li><a href="http://www.tirerack.com/wheels/tech/wheeltech.htm">http://www.tirerack.com/wheels/tech/wheeltech.htm</a</li></ul>
Old May 29, 2002 | 03:07 PM
Junior Member
Thank you.
Old Jun 4, 2002 | 09:52 AM
Eddie@Tirerack's Avatar
Member
Thanks PeteH!
pink shrimp
28
May 30, 2007 03:34 PM
2002wagA4
11
Sep 24, 2003 05:52 PM
ryoung
Apr 15, 2001 05:22 AM
Wade(4.2-2.4)+T
Nov 13, 2000 02:30 PM
Matt
Sep 28, 1999 08:31 PM
