Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Tire question. Will a 215 fit an 8.5" wide wheel?
Old Jun 3, 2002 | 05:28 AM
AWOT extra 23052's Avatar
Senior Member
Default Tire question. Will a 215 fit an 8.5" wide wheel?
The tire is a 215 40 18 on an 18x8.5" wheel.
Old Jun 3, 2002 | 06:28 AM
ex-quattro PETE's Avatar
AudiWorld Expert
Default it'll fit ...
just barely... it may look a bit awkward, since the tire will be so streched on this rim. Plus, your rim will be subject to easy damage/curb rash as the tire is not wide enough to offer any protection.
Old Jun 3, 2002 | 03:30 PM
Ted K's Avatar
Default Why would you want to go so narrow a tread. I have 225s on 8" wide wheels, and the sidewalls are
almost straight. I think you could almost go to 235s on an 8.5" wide wheel.
Old Jun 4, 2002 | 09:11 AM
Eddie@Tirerack's Avatar
Member
Default Well..
As QP said, it will- the spec for that is Rim Width Range from 7.0" to 8.50" wide.
It WILL look stretched on the sidewall. For an A4 i suggest a 225/40R18- more common size for better selection & much better mounted 'look' to them.
Cal me if I can help or to place an order!
Old Jun 7, 2002 | 07:47 AM
Senior Member
Default Cause I rub with a 225.
Rather then sell my BBSs, if I replace the Michelins with either something with a more squared profile, or something with a narrower tread, the rubbing might resolve itself (with a little help).
Old Jun 7, 2002 | 08:07 AM
AudiWorld Expert
would adding spacers or rolling fenders be an option instead?
Old Jun 7, 2002 | 10:10 AM
Senior Member
Default Rolled fender in the front yes, in the back no.
The tires, under extreme driving conditions, touches the rear liner. Adding spacers would move the wheels the wrong way. Quattros don't rub but FrontTrak does.
Old Jun 8, 2002 | 04:24 AM
Senior Member
Would a 215 be a better fit on an 8" wide wheel?
 Pouria Savadkouei
 Michael S. Palmer
unc99206
Apr 3, 2006 03:41 PM
David
Apr 15, 2004 05:17 PM
BVRN_RKT_94_90
Sep 12, 2003 09:01 PM
kkouddous
Jan 9, 2003 07:48 AM
Kim @ MotorKlasse.com
May 30, 2002 09:35 AM
