Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
What is max size (width) tire that can fit in stock 16" 5-spoke wheel on '00 A6 2.7T?
Old Jun 6, 2002 | 08:07 AM
A6TwinTurbo's Avatar
Old Jun 6, 2002 | 08:56 AM
Eddie@Tirerack's Avatar
Member
Default Re: What is max size A6 2.7T?
Either a stock 215/55, or you can move up to a 225/55-16 (25.7" overall)
Call me if I can help you with an order!
Old Jun 6, 2002 | 09:29 AM
ex-quattro PETE's Avatar
AudiWorld Expert
Default assuming the rim is at least 7" wide, then...
you should be able to put on a 235/50 tire on it, which is almost exactly the same in diameter as the stock 215/55.
If you don't have any rubbing with your summer 245-wide rubber, then there shouldn't be any problem with 235s either.
Old Jun 16, 2002 | 08:16 AM
Thanks, I think I will go with new 8" wide wheels ....
RomanA6
31
Dec 14, 2006 10:19 AM
TSimo
Nov 8, 2003 12:04 PM
technokid
Jul 26, 2002 05:46 AM
vern
Feb 10, 2000 07:18 PM
vern
Jan 27, 2000 01:58 PM
