Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Have stock RE040's, anything I can get that will reduce the horrible tramlining?
Old Jun 9, 2002 | 06:27 PM
Bozman's Avatar
Default Have stock RE040's, anything I can get that will reduce the horrible tramlining?
For summer I am running the stock Bridgestone RE040's. I just moved to MA this past October and almost right away put some winter tires on (which were AWESOME choices btw. Thanks to Luke @ Tirerack!). I never noticed a problem with the Bridgestones in Tampa, FL but after I took the winter tires off up here and slapped the stock ones back on, I was horrified! My first trip down Route 2 with the summer tires and I thought I was going to drive straight into the ditch! The tramlining with these is atrocious, so much so that I now dread the 45 minute drive to work which I used to enjoy and look forward to winter just so I can put my winter tires back on. Is there anything I can get in the stock tire size that will tramline less without greatly sacrificing performance? I was considering the SP-03's.. Any suggestions?
Should I be looking at a different rim/tire size if I really want to fix this problem?
Thanks in advance.
Old Jun 10, 2002 | 10:12 AM
ex-quattro PETE's Avatar
AudiWorld Expert
Default some suggestions...
1. Increase air pressure in your RE040s, if you haven't already. This will slightly decrease the contact patch and may also increase fuel economy.
2. Try buying tires that do not have a continuous strip of rubber going all the way round. Not sure if RE040s have it or not.
3. As far as I know, once you get into 225-width, most (if not all) summer tires tramline a bit. My S-03s tramline, but only at very low speeds. Once I go above 30 mph, there's no problem, but just to be on the safe side, I always keep a firm grip on the steering wheel.
4. If all else fails, buy some cheap all-season rubber. With the limited grip they have, the tramlining will be less pronounced as well ;-)
Old Jun 10, 2002 | 03:37 PM
Larry T's Avatar
New Member
Stupid question...What is Tramlining?
Old Jun 10, 2002 | 06:56 PM
AudiWorld Expert
Default Re: What is Tramlining? ...
The first paragraph of this article explains it pretty well:<ul><li><a href="http://www.autospeed.com/A_0879/page1.html">http://www.autospeed.com/A_0879/page1.html</a</li></ul>
Old Jun 12, 2002 | 04:37 AM
Eddie@Tirerack's Avatar
Member
Agreed- good post!
Old Jun 17, 2002 | 04:09 PM
Flask's Avatar
Default What kind of tire pressure do you suggest?
I run 37lbs cold in my 225/45s and it still tramlines at speeds under 30mph
Old Jun 17, 2002 | 07:29 PM
AudiWorld Expert
Default Re: What kind of tire pressure do you suggest?
I run 39F/37R.
I don't know why, but I don't notice my car tramline any more. I only noticed it the first 500-1000 miles or so. Either I got used to it or it went away. Weird.
JZK26
Jun 24, 2021 06:41 PM
RFS
S6 / RS6 (C7 Platform) Discussion
Feb 19, 2015 12:22 PM
TTinCT
16
Nov 10, 2004 09:06 PM
hearnje
Nov 23, 2002 10:25 AM
HPH
Audi allroad
9
Oct 15, 2001 08:21 PM
