Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Will this setup fit on a b5 s4 with h&r sport springs and bilstien shocks?
Old Mar 9, 2005 | 04:25 PM
alleuroS's Avatar
Default Will this setup fit on a b5 s4 with h&r sport springs and bilstien shocks?
235/40/18 on 18*8 wheel offset 33 FRONT
265/35/18 on 18*9 wheel offset 35 REAR
Old Mar 9, 2005 | 04:29 PM
clean.'s Avatar
Senior Member
Default that rear set up will rub for sure
you'd have trouble stuffing a 265 series tire in the rear wheel wells of a lowered B6 let alone a B5.
Old Mar 9, 2005 | 05:07 PM
alleuroS's Avatar
Default can i run 235/40/18 in front and 255/35/18 in rear??? anyone know the formula to figure out
the rolling diameter of a setup? thanks
Old Mar 9, 2005 | 05:40 PM
CraigB's Avatar
AudiWorld Expert
Default here's an easier way
<ul><li><a href="http://www.miata.net/garage/tirecalc.html">linky</a></li></ul>
Old Mar 9, 2005 | 06:53 PM
jmt7's Avatar
New Member
Default Re: here's an easier way
you're a savior lol
great link
Old Mar 10, 2005 | 12:09 AM
The R's Avatar
Default Depending on brand of tire, you might rub in the front as well.
You might clear with Yokohamas or Falkens, but if you're thinking about BFG KDW2s, there's no doubt in my mind you'll rub cause they run wide. S03s will probably cause you a little grief as well.
Old Mar 14, 2005 | 01:15 PM
fallzboater's Avatar
Default Handling will be worse.
These cars already understeer badly, even with sport springs. Will be even worse if you go bigger on the rear.
snowpunk_AGTT
9
May 4, 2008 03:53 PM
myaudi_a4wagon
Feb 25, 2008 03:06 PM
Distinct
Canadian Discussion
May 13, 2005 08:10 AM
tai
Mar 18, 2005 05:02 PM
smb1234
Sep 28, 2004 01:49 PM
