Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
What causes this...
Old Mar 29, 2005 | 06:39 PM
co859's Avatar
Default What causes this...
These tires are Toyo T1-s. I have the same ones and have the same problem...I have a few ideas of what it could be...maybe because of no camber kit installed? Any suggestions?<ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/800766.phtml">https://forums.audiworld.com/a4gen2/msgs/800766.phtml</a</li></ul>
Old Mar 29, 2005 | 07:05 PM
jprice@CPS's Avatar
Member
improper camber or toe (or both)
Old Mar 29, 2005 | 07:32 PM
Russ Scott's Avatar
Default it's caused by the "single compound" (soft 'n sticky)
tread used in the now, "old school" T1-S. Newer "dual" or "multi" compound tires like the Goodyear GSD3, Michelin Pilot Sport 2, and the Toyo T1-R, use harder or more wear resistant rubber on the inner portion of the tread. High negative camber settings, used in sport tuned cars, place a higher load on the inner tread. The soft T1-S's treads wear rapidly as a result (mine lasted 15k miles). Newer designs resist this wear thanks to "harder" inner tread compounding and remain "sticky" thanks to softer compound used for the remainder of the tread.
Old Mar 29, 2005 | 09:35 PM
jprice@CPS's Avatar
Member
I should say "agressive" camber, not improper.
A4NCAR
21
Jan 31, 2004 01:03 AM
markbradford
Motorsport Discussion
Mar 12, 2003 09:25 PM
ryoung
Mar 26, 2002 08:49 AM
VladN
Jan 28, 2002 10:02 AM
