Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
TT wheel help: Do all wheels fitting Golf/Jetta/Bug fit TT?
Old Apr 19, 2005 | 01:18 PM
audesign's Avatar
New Member
Default TT wheel help: Do all wheels fitting Golf/Jetta/Bug fit TT?
I am looking for some 18" rims for my TT. I have found several 5x100 that I like, that list they fit Jetta, Golf, Beetle, but do not list TT. The guy says the TT has 14mm bolts, but the wheels are designed for 12mm bolts. Is there any truth to this? Thanks.
Old Apr 19, 2005 | 01:26 PM
CraigB's Avatar
AudiWorld Expert
lug bolts are the same for Golf, Jetta, Bug & TT...also, Passat & other Audis
Old Apr 19, 2005 | 03:04 PM
Cameron's Avatar
AudiWorld Uber User
Default Ahem, careful there, CraigB.
Lug pattern is the same, lug bolts are not always the same spec length.
Old Apr 19, 2005 | 03:30 PM
CraigB's Avatar
AudiWorld Expert
Default Ok...
The lugs are exactly the same for the 02 GTI, B5A4 & B5S4. I have MTM spacers/lugs that I used on all 3 cars. Lug length could be different between some models, but he was asking about 14mm vs 12mm drilled wheels. All the cars he listed should be 14mm.
Old Apr 19, 2005 | 03:55 PM
Gary@Tirerack.com's Avatar
Former Vendor
Default When you say 'they' list to fit, who is 'they' in this case?
I ask because there may be other reasons that it is not listed to fit, such as brake clearance issues. If they are a wheel company or wheel seller, they should be able to tell you whether or not the wheel you have in mind will fit your specific application.
audesign
22
Apr 21, 2005 03:44 PM
HACK THS
9
May 7, 2004 06:50 PM
mhc
May 28, 2001 08:32 AM
x-ricer
Apr 3, 2001 09:28 AM
