Offset question when changing wheels, STFA no definite answer
1. What does this do to the handling characteristic of the car?
2. Any alignment/camber issues (no drop in suspension, just a wheel change)?
3. Ideally, should there be an adjustment when changing the offset?
TIA.
Besides giving the car a better look, it will improve your handeling because the tires are pushed out a bit more. There will be no alignment/camber issues because no suspension parts are being affected by the offset change which means that no adjustments need to be done. I hope this helps.
Leo
leo@edgeracing.com
800-489-5353 x211<ul><li><a href="https://www.edgeracing.com">https://www.edgeracing.com</a</li></ul>
