Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Gary can you please help out with a fitment question for BBS RGR?
Old Oct 5, 2007 | 06:23 AM
G18's Avatar
G18
Default Gary can you please help out with a fitment question for BBS RGR?
Tirerack website shows the BBS RGR 18x8 5x112 with et35 fitting a B7 S4 but not fitting on a B7 A4. The site does show the wheels fitting a B7 A4 in a 17" size though with the same width and offset.
I know these 18" wheels work on a B6 S4 which I thought had the same brakes as a B7 A4.
Will the BBS RGR 18x8 et35 work on my B7 A4?
I've been searching for a bit but can't seem to find an answer any help would be appreciated.
TIA
Old Oct 5, 2007 | 01:18 PM
Gary@Tirerack.com's Avatar
Former Vendor
Default Re: Gary can you please help out with a fitment question for BBS RGR?
From the specs I see here they should fit. If you need to order in the meantime, its okay to use the 05 A4 as the lugs and tire fitment will be the same, or you can always call in the order to me directly. There is a note that brake clearance is different between the various models and to check clearance on this before installing.
Old Oct 5, 2007 | 01:26 PM
G18's Avatar
G18
thanks a lot Gary, appreciate the help as always : )
jlive1980
Nov 27, 2006 04:18 AM
LavaGrau_A3
May 22, 2006 07:46 AM
dbex
Jan 16, 2005 08:35 AM
TimB
Nov 4, 2003 11:33 AM
plum
Aug 7, 2003 12:20 AM
