Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Wheel Noise
Old Oct 27, 2007 | 07:45 AM
John A's Avatar
New Member
Default Wheel Noise
I have a scraping noise on my front right wheel on my 2004 Audi A4 quattro. I have had the wheel bearing replaced and suspension taken apart and put back together. The service department is stating that the tires need to be replaced because they are worn down too much and this could be making the noise. It sounds like the rotors and brake pads are scraping everytime the wheel turns, but those were checked and not causing the problem. The noise only happens when under 10 MPH and when braking. Anyone else experience this problem or have any idea what it could be?
Old Oct 28, 2007 | 08:12 AM
- GT Style -'s Avatar
Lane Shark
Splash guard rubbing on rotor?
Old Oct 30, 2007 | 09:19 PM
Reggie's Avatar
Club AutoUnion
25 Year Member
Default what happens when you tap the brakes at 10mph - does the sound go away?
If the caliper pins are tarnished or corroded - it will cause the pads to stick
Old Nov 1, 2007 | 08:13 PM
theonlineguy's Avatar
New Member
Default have you worked on the brakes recently?
something similar happened to me, the shop i took my car to to replace cv boot didnt tighten the bolts holding the brake caliper on, so the rotor would be pulling the brake caliper everytime i hit the brakes... sounds possible...
Alex
Feb 3, 2006 07:14 AM
garibaldi
Apr 23, 2005 10:35 AM
dirtyhands
Audi 100 / A6 (C4 Platform)
Mar 25, 2005 05:28 AM
ijdude
Feb 18, 2003 12:27 PM
trd_3000
Jul 9, 2002 05:07 PM
