Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Snow tire height question on B5 A4...
Old Nov 7, 2007 | 05:36 PM
AvantBlue's Avatar
Default Snow tire height question on B5 A4...
I will be putting snows on some used 16" Swing wheels. Tire Rack shows a Blizzak WS-60 in 205/60-16 as $16/tire cheaper than a stock size 205/55-16. Is it worth it?
Miata.net tire calculator says it's .8" taller. Is this an issue on a B5? I've always been told a little taller tire is better in winter anyway.
Old Nov 7, 2007 | 09:25 PM
jprice@CPS's Avatar
Member
personally I'd go with 205/55/16. Wait.. I did! ;-)
Old Nov 8, 2007 | 08:39 AM
ski ya later's Avatar
Default since you're getting a great performing snow tire, I would not get the taller/narrower tire..
I would go with the 205/55 , then you would have great snow performance and still descent dry handling.
Old Nov 8, 2007 | 08:54 AM
AvantBlue's Avatar
Did you buy the WS-60? In MN, you would know about snow and ice!
Old Nov 8, 2007 | 02:40 PM
jprice@CPS's Avatar
Member
I have the Nokian Hakka2 on my car, and Michelin X-Ice on my wife's vehicle.
Old Nov 8, 2007 | 02:41 PM
jprice@CPS's Avatar
Member
Default Decent dry handling?
Have you ever driven on a new Blizzak WS15 or WS50 or MZ01 or MZ02 or Revo1 or WS60? (or any of the other Q rated blizzak models)
I'm going to go with no ;-)
Old Nov 8, 2007 | 03:46 PM
AvantBlue's Avatar
Nokian RSi $217, Tire Rack WS-60 $127, local WS-60 $137, all mounted & balanced.
Old Nov 8, 2007 | 07:46 PM
Default haha, you're funny!!
I will qualify (since you thank I need to) that with a snow tire, dry handling is all relative, as it WILL be less than any other type of tire. What I was refering to is that you will have better dry handling in the wider tire than the taller/narrower tire. I would assume that anybody buying a dedicated snow tire like the Ws-50 is not looking for great dry handling anyway as they will not get it. Make you more comfortable?? BTW I have driven on ALL of those tires you listed above, in ALL conditions, including the Bridgestone Ice track - which is where I got to test most of them
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 8, 2007 | 08:25 PM
jprice@CPS's Avatar
Member
Default I don't like the RSi... ran it for a winter and it was too soft on dry pavement for my taste..
though it isn't as soft as the blizzak Q rated tires.
I have been impressed with the Michelin X-Ice for being an all round winter tire.
Luckily I bought the Nokian Hakka2 before the exchange rates got real bad, so didn't have to pay too much more than your blizzak pricing :-)
I'd say if you're going to do a LOT of driving on glare ice, the blizzak WS60 is a good choice. If you drive a lot on dry pavement, especially highway, but still want a tire that does good on the ice, I'd lean toward the X-Ice. Tirerack sells both.
The thing I don't like about the blizzaks with the tube multicell compound (their Q rated winter tires), is only the outer half of the tread. I like tires that have a consistent compound from base to tip.
Old Nov 8, 2007 | 08:50 PM
AvantBlue's Avatar
Default Snow, packed snow, ice, slop, black ice, and maybe a teenage driver using it...
I agree on the Blizzak tread, but keep in mind that a half-tread snow tire isn't much of a snow tire anymore. It's not the kind of tire you wear down to the nubs to get your money out of it - you have to replace them fairly often. I don't run them until it gets sloppy and icy enough to really need them, then they're off again as soon as it warms up - they still only last 3 or 4 seasons.
llonman
10
Nov 12, 2004 03:30 PM
Phil Manro
Aug 29, 2003 08:39 AM
Santorin Drm pig pal
9
Apr 29, 2002 01:32 PM
BahnBomber
Dec 27, 2001 05:21 PM
