Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Q re: tire pressure for winter tires (3 psi higher than summers?)
Old Nov 20, 2007 | 06:43 AM
jhoeppel's Avatar
Default Q re: tire pressure for winter tires (3 psi higher than summers?)
In the owners' manual of my '01 TT, it states that (and I'm paraphrasing here) "...due the nature of winter tires, they must be inflated to 3 psi above" that required for other tires. Is this really true? Should I run my winters 3 psi above my summers? The placard on the fuel flap recommends 33f/30r psi, but of course doesn't mention summer or winter.
<i>'01 TT quattro, running 17" Dunlop 3Ds for winter</i>
TIA, ~john
Old Nov 20, 2007 | 06:51 AM
NYImola::NYMisano's Avatar
Member
Default In general
correct me if Im wrong:
Sidewalls are not as stiff on winter tires and require higher pressure to offer the same rim protection from potholes.
Higher pressure also gives you a smaller contact patch increasing traction in snow
Old Nov 20, 2007 | 07:32 AM
ski ya later's Avatar
yes, but will wear tire out in center of tread faster.
Old Nov 20, 2007 | 07:54 AM
Reggie's Avatar
Club AutoUnion
25 Year Member
yes
Old Nov 20, 2007 | 08:10 AM
jhoeppel's Avatar
which means "normal" pressures for best all-around use?
Old Nov 20, 2007 | 08:50 AM
Reggie's Avatar
Club AutoUnion
25 Year Member
Default I would say Tire Rack would have recommendations on their website
if they felt additional pressure was important.
But if someone is an aggressive drive - higher pressures would probably give better wear.
cufish
Nov 2, 2004 12:27 AM
jhoeppel
Dec 8, 2003 09:51 PM
DanosS4
Dec 4, 2002 09:00 AM
Tim
Oct 22, 1999 04:58 PM
Roy M
Nov 16, 1998 06:50 AM
