WINTER TIRES: Winterforce vs. Hakkas vs. Green Diamond
I am currently looking at the Winterforce M+S, some kind of Nokian Hakka's, or Green Diamond Icelanders.
Winterforce:
Pros: CHEAP!! Really good in the snow. Great value.
Cons: "You get what you pay for"? Soft sidewalls, noisy(not a huge issue to me), squirmy on dry pavement--however, these are dedicated snow tires, you cant expect much in the way of great dry handling etc etc
Nokian Hakkas:
Pros: Excellent in the snow. Also pretty good on dry.
Cons: Expensive
Green Diamond:
Pros: Cheaper than Nokians. Cool little studs that pop through after a bit of wear. Save the environment by using remolded tires.
Cons: I cant find many reviews. Not sure how I feel about the safety of remolded tires. Need to be "broken in" for about 500-1500 dry road miles before the "studs" come through. Oh, and currently out of stock in the size I need.
Im definantly leaning towards the Winterforces because of the price and the fact that they seem to get a ton of great reviews.
Does anyone have any comments about which I should go with, or stay away from?
Check the speed rating on the Winterfroce tires, IIRC, it is not adequate for an allroad.
I would never buy a remolded tire. It's jus tone of those thing you don't mess with -- Tires and Brakes.
I dont need studded. I will be in New Mexico for college(still snows down there), but then in Colorado for my breaks. Im also a pretty avid skier, so I get up to the mountains a fair bit. However, I have spent a few winter seasons in Colorado on all-season tires with quattro and gotten by just fine. Winters will just be an added bonus.
I will check out those Hankooks.
even dunlop wintersports are a still a bit expensive at $140/tire. heard great things about these, and was going to run the M3's last winter on my A4 but one of the wheels i was going to use was bent.
If I were buying winter tires right now I would get the Hankook iPike W409, which has a blatant copy of the Nokian Hakka5's tread pattern.
A few people here in Minneapolis ran those last winter and the tires performed very well! They were an incredible bargain. I would run them in a heart beat.
I've run the RSi's for the past two seasons on mostly dry pavement. They are astonishingly good in the snow and ice (considering they aren't studded) and still handle very well in the dry (much better than Dunlop Wintersports on both counts). Previous to the RSi's I've run WR's which were a tad better in the dry, a tad worse in snow, and no match for the RSi's on ice.
I've used Bridgestone and Yokohama winter tires in the past as well, and the Nokians have always been worth their premium when I find myself in nasty weather. It's also worth noting that the lifespan of both Nokians is substantially better than any of the other tires I've had (which helps to offset the cost). I'd estimate that I got 50-75% more mileage out of the Nokians before the winter traction degraded to the point of a regular M+S all season tire.
I've also had some off brand winter tire (I want to say Winterforce but I'm not 100% certain), and they got downright dangerous as they aged. The compound hardened to the point where they were worthless in the snow, cold, and even plain old wet pavement.
That makes no sense. "Low profile" is a general and vague term as it is. If someone has brakes that require 17" minimum wheels for clearance (many OEM brakes now), they don't need snow tires?
