Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Winter tires question(Gary and others)--- B6 S4
Old Aug 12, 2008 | 07:13 PM
fredbourgeoismtl's Avatar
Default Winter tires question(Gary and others)--- B6 S4
looking to get some winter tires. Not sure if I really need to go for 17in. It will be cheaper to keep my stock 18 wheels than buy a new set of rims. I'm driving 90% in city. I live in Montreal, Canada. I Almost never drive in snowy road. Road are cleared fast and there is more ici than snow. So:
1. Should i really downgrade to 17 inches wheels?
2. What do you think of the new Michelin PA3. Any better choice?
Best regards
Old Aug 12, 2008 | 07:32 PM
jprice@CPS's Avatar
Member
Default Take a look at the Dunlop Wintersport 3D
<a href="http://www.tirerack.com/a.jsp?a=AR4&url=%2Ftires%2Ftires.jsp%3FtireMake%3D Dunlop%26tireModel%3DSP%2BWinter%2BSport%2B3D%26ve hicleSearch%3Dfalse%26partnum%3D34VR8WS3DXL%26from Compare1%3Dyes%26place%3D3">http://www.tirerack.com/tires/tires.jsp?tireMake=Dunlop&amp;tireModel=SP+Winter+ Sport+3D&amp;vehicleSearch=false&amp;partnum=34VR8 WS3DXL&amp;fromCompare1=yes&amp;place=3</a>
Old Aug 13, 2008 | 04:21 AM
Gary@Tirerack.com's Avatar
Former Vendor
Default Re: Winter tires question(Gary and others)--- B6 S4
If you are truly dealing with very little snow and mostly ice you'll want an ice compound winter tire like the Blizzak WS-60, which are only available in 17". The PA3 will have better dry grip and steering response but will be a significant step down in ice and snow traction from the WS-60.
Old Aug 13, 2008 | 04:28 AM
Default Ws60 are listed as 94R
Will it be problematic for a sport sedan as the S4? Do I really need XL? What abour the Dunlop 3d? Any user of Ws60?
Old Aug 13, 2008 | 07:53 AM
jprice@CPS's Avatar
Member
Default I read your question wrong. Gary is right, if you see a lot of ice, you want a softer compound
I think the best non-studded ice tire you're going to get in 18" is the Nokian RSi in 225/40/18 (should fit on your stock wheels), however be prepared to spend a lot for those unless pricing is different in CA vs US on them. If you can and want to run studs, there's more options as well.
Going to a 17" wheel and 225/45/17 or 235/45/17 will open a lot of other tire options for you that will handle the ice well.
Old Aug 13, 2008 | 09:05 AM
Default 1343$ installes for rsi
1343$ cdn installed. tx in. Not cheap but in canada they are alot cheaper than blizzak. Where do you live j price? You have dunlop 3d? Are you happy with them? With tire rack, i can expect to pay 850$ for Dunlop. 500$ difference. Its hard for me to explain how winter is uphear. Some years, its snowy, some not.
Old Aug 13, 2008 | 09:33 AM
jprice@CPS's Avatar
Member
Default Sounds expensive
I'm in Minneapolis, MN.
I have driven on the M3 and 3D, but I personally prefer more agressive snow tires. I have been really happy with my Nokian Hakka2s (without studs), which are halfway between an RSi and the
3D in terms of dry road performance and ice traction as well. The newest version of those is the Nokian Hakka5. I find it to be the perfect balance for me where we do get a few good snow storms every year, icy roads sometimes, and a lot of cold dry road surfaces. Tires like the 3D, LM25, and PA3 give up too much in snow and especially ice for my taste, and the soft blizzaks like WS50 and WS60 give up too much on dry pavement. Even the Nokian RSi which is better in dry than the soft blizaks still are too squirmy for what I wanted.
The 3D is a high performance winter tire, which means it handles the dry pavement better, but gives up ice traction as a result.
If you were looking at 18" Blizzaks, then they were most likely the LM25 which performs similar to the Dunlop 3D. The 17" Blizzak WS60 that Gary mentioned is much softer and does well on ice. Completely different tires.. just similar in name.
Old Aug 13, 2008 | 09:39 AM
Default Xice 2?
Are rated 97T XL. Maybe the perfect compromize Between Dunlop 3d and ws60? New technology too. Consomer reports rated the old xice #1 years ago.
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 13, 2008 | 09:48 AM
jprice@CPS's Avatar
Member
Default I have the original X Ice on my wife's car...
They are a very good tire on the dry considering they do well on the ice. However I didn't think the X Ice 2 was in a size that was correct for the B6 S4? (235/40/18 or 225/40/18)
Old Aug 13, 2008 | 09:51 AM
just in 235-45-17 97t XL
