Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
hub centric question - kinda long
Old Sep 12, 2008 | 07:15 PM
UrbanAssaultAudi's Avatar
Default hub centric question - kinda long
Purchased some ATS type 10 wheels for my 88 90Q and i'm having a bit of a measuring issue with trying to find the right hub centric rings.
Les Schwab measured the ID of the wheels, told me it was 60mm. So I ordered 57.1 X 60mm rings thru Discount tire and had them install them.
Had a n00b at Discount tire installed them, obviously weren't the right fit as the vibration was still there.
If I pop the center cap out of the wheel, you can physically see that it is not centered on the hub. I finally got fed up with the vibration yesterday and pulled the wheel myself and measured. I used a compass and transferred the measurement to an analog caliper and got 64.7mm.
Digging through my stash of papers, I found the original TUV document that came with the wheels. Showing the translation (mittenlochdurchmesser des rades)
diameter hole through the middle of the wheel is 63.4mm.
<a href="http://www.1010tires.com/hubrings.asp?gclid=CPTi4d7j15UCFRGiiQodHzQZWg">Thi s site</a> lists a 57.1 x 63.3 ring. Should I take my chances and go off the documentation that came with the wheels? Or modify/make something for the measurements that I took?
Could my measurements be wrong?
Suggestions?
TIA
Old Sep 13, 2008 | 06:49 AM
Reggie's Avatar
Club AutoUnion
25 Year Member
Default Check over at ryans site
<ul><li><a href="http://www.audihelp.com/forums/YaBB.pl">Link</a></li></ul>
Old Sep 27, 2008 | 03:23 PM
problem fixed with 57.1mm X 63.3mm rings
Old Sep 27, 2008 | 05:24 PM
Reggie's Avatar
Club AutoUnion
25 Year Member
Great
TonyMastodon4k
Jun 7, 2009 08:13 PM
sizzle
Mar 3, 2008 08:53 AM
maclem8223
Dec 13, 2006 10:15 AM
Till222
Apr 2, 2003 05:39 PM
Flask
Feb 5, 2001 01:22 PM
