Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
XL tire questions
Old Sep 22, 2008 | 05:29 AM
Fairlady's Avatar
Default XL tire questions
I got a set of Yoko 520 for my 2006 A4 3.2. It is a XL rating tire. Does it mean it is a low profile tire or just reinforced sidewall?
I noticed the car pull to the right slightly so I need to bring the car back for an alignment check. I didn't expected this issue on new tires.
Old Sep 22, 2008 | 07:30 AM
Just Me's Avatar
Tech Guru
Tech Guru
Default XL is extended load. Reinforced sidewall, generally.
Pulling can be either tire wear or alignment. generally alignment, which is unaffected by whether a tire is new or old.
Old Sep 22, 2008 | 07:35 AM
Fairlady's Avatar
Default Re: Thanks. They put in diff PSI than the spec too.
The DiscountTire guy put in 32psi instead of 35psi (35 was recommended by Audi). They told me it's due to the XL rating.
They didn't follow the yellow/red marks as indicated in the Yoko 520 installation instructions so I may go back to them.
Old Sep 22, 2008 | 07:57 AM
Just Me's Avatar
Tech Guru
Tech Guru
Default I'm not sure why XL would change the suggested pressure....
I'd double check that.
Old Sep 23, 2008 | 06:04 AM
Gary@Tirerack.com's Avatar
Former Vendor
Default Agreed.
XL tires get their extra load capacity by being able to be inflated to higher inflation pressures. Lower psi will lower the load capacity on an XL tire just like it would on a standard load tire.
1999Audi
Apr 12, 2014 05:07 AM
NCAudiFan
S4 (B8 Platform) Discussion
28
Feb 1, 2011 10:13 PM
C-Nutts
Dec 10, 2003 02:23 PM
