Bore holes too small - what do I do? OK I bought a set of wheels w/ 12mm
1. Drill out at a cost of approx. $200; 2. Use an adapter stud that has 12mm male on one end and 14mm on the other at a cost of $60 incl. nuts. I got these wheels for track use so they need to be safely mounted. Is the adapter stud a safe way to go?
Bill/Memphis
Drilling out will be OK only if you get them exactly right - not off by a thousandth or two. Note that a jig wont solve the problem - if the entire jig's off, the wheel will be eccentric again.
Return them. Bite the bullet, IMNSHO.
Grant
Bill/Memphis
