Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Gary: question about TR test results...
Old Nov 13, 2008 | 07:52 PM
ex-quattro PETE's Avatar
AudiWorld Expert
Default Gary: question about TR test results...
I'm looking at these two UHP all-season tire tests, both done on E90 328i; one in August, one in May.
http://www.tirerack.com/tires/tests/testDisplay.jsp?ttid=115
http://www.tirerack.com/tires/tests/testDisplay.jsp?ttid=106
The August one shows:
<img src="http://www.tirerack.com/images/tires/tests/mi_psas_plus_rd/chart5.gif">
And May one shows:
<img src="http://www.tirerack.com/images/tires/tests/bfg_gForce_SuperSport_AS/chart5.gif">
Why such significant difference in wet stopping distance for RE960 between the two tests (104.9 ft vs 92.4 ft)? The only variable that may not have been kept constant is ambient temperature.... but there surely must be something else at play?
Also a very big difference in Average Cornering (g-Force) in the wet (0.79 vs 0.88).
Old Nov 14, 2008 | 07:17 AM
Gary@Tirerack.com's Avatar
Former Vendor
Default Re: Gary: question about TR test results...
Brake pad wear/type, amount of water on the track (pouring rain is more effective or high humidity is more effective than just our sprinkler system alone on a dry day), and yes, ambient temps.
Old Nov 14, 2008 | 09:09 AM
Reggie's Avatar
Club AutoUnion
25 Year Member
Default I did not look at the results closely but was the comparison between tires brands
the same results? I would think that would be the real test results to compare.
Old Nov 14, 2008 | 01:00 PM
AudiWorld Expert
Default Well, OK, but wouldn't those variables similarly affect all the tires?
Yet the two tests show that:
1) RE960 has gotten significantly worse results from May to August
while
2) GY F1 A/S has actually improved its wet stopping performance (from 100.4ft in May to 96.6ft in August)
Sorry, maybe I'm just nitpicking.
Old Nov 15, 2008 | 05:16 AM
Former Vendor
Default Re: Well, OK, but wouldn't those variables similarly affect all the tires?
Similarly, but not the same exactly. Keep in mind that these tires, while in same catagory do come from different manufacturers with different compounds, tread patterns, etc that could react differently to changes in conditions.
No apologies needed for nitpicking
simonaitch
Mar 9, 2015 11:32 AM
JDM05
Jul 25, 2009 10:27 PM
ScottCSC
Aug 30, 2006 04:20 AM
ski ya later
May 7, 2004 07:37 AM
Rave'nGTi
Jul 12, 2001 07:02 PM
