Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
wheel selection
Old Nov 23, 2008 | 07:21 PM
C4A6Q's Avatar
Default wheel selection
i have a 1996 a6 quattro, im looking for wheels and im wondering what size i shouls go with. can i fit 20's? any suggestions?
Old Nov 23, 2008 | 07:26 PM
jprice@CPS's Avatar
Member
Why go with 20s when you can jack it up and do some blang blang 24s!?
Old Nov 24, 2008 | 07:40 AM
Reggie's Avatar
Club AutoUnion
25 Year Member
Default Only if you remove half your IQ
OK - joke over. 20" rims on that car really does not offer you much. There is no performance gain and on some Audis looks terrible which is probably what you are aiming to do. Most of us on Audiworld are more interested in the gains mods make to give us better performing cars.
I would spend some time on the A6 forum and see what people have done. You can go to the Tire Rack as they have plenty of wheels and a website that shows you what those wheels look like on your car.
If you have not purchased winter tires and wheels for your car - I urge you to do so soon before the tires supply diminishes.
Old Nov 24, 2008 | 09:28 AM
Just Me's Avatar
Tech Guru
Tech Guru
Default Well, I'm sure you CAN make it fit .... but why?
Larger wheels will clear brakes. You simply need to make the tire smaller and smaller to maintan the same, or a similar, OD. That's the rub with all these bling-y things - you wind up with all wheel and no tire.
The mass goes up
Your acceleration goes down
ride gets worse
Tire cannto protect the wheel, so wheels get bent, and then vibrate
and the list goes on.
Frankly, on my S6 ( S mind you) I went from factory 17s to 16s. very wide light 16s.
now most feel i'm a bit retro. or a lot retro, but certainly 17s are about the largest you really want. After that you gain weight, and risk damage. Plus the ride sux.
The ideal 17" wheel is 17" x 8" x -35mm offset; 5 x 112; 14mm bolts.
But if you really want them, remember these important words: D=2*r; R=wheel/2+width*aspect ratio ( remember to convert millimeters to inches!); C= 2*pi*r. The rest is up to Mr. Excel.
G
Old Nov 24, 2008 | 07:17 PM
ex-quattro PETE's Avatar
AudiWorld Expert
20s are for wussies. Go for 25s and skip the tires.
Old Nov 25, 2008 | 04:18 AM
finiki's Avatar
Default Maybe 20" but 19" will, 18" is a good compromise...
20" will ride very harshly & you will risk both wheel & tire damage. The 19" will work out OK & look good. I have found the 18" to work best for me, the ride is good, they handle way better than 16 or 17" & they still look distinctive. The bigger wheel & lesser tire sidewall without doubt provide better handling. Keep in mind too the bigger inside diameter tires cost more money. Tire Rack & Discount Tire have a whole lot of options that you can view on your car model. It is not always about the ride, style points count too.
NealcpLA
Q5/SQ5 MKI (8R) Discussion
Mar 23, 2017 03:56 PM
ECS Tuning-Audi
Nov 6, 2014 11:55 AM
ECS Tuning-Audi
Nov 6, 2014 11:38 AM
Tapakegovagnaps
Mar 21, 2007 07:34 AM
DMY 2.7T
Nov 18, 2000 09:48 AM
