pros and cons of this harness bar? if you have the Stable Energies bar, what belts are you using?
Is there a place to mount the 5th belt? I'm not sure I like the idea of the 5th belt with the stock seat since you can't go straight down. But, is having that 5th belt still better than not having it there at all? When I use my current 4-point, it tends to ride-up on me, which is why I often using the 3-point over it and leave the 4-point a little loose. I just don't feel this is the safest method and want something better.<ul><li><a href="http://stable-energies.com/prodinfo.asp?number=GBA4">http://stable-energies.com/prodinfo.asp?number=GBA4</a</li></ul>
From Schroth's claims, 4pt harness are designed not to submarine. For instance the lapbelts will tie into the oem anchor points so that the oem pretensioner helps. Also the location where the shoulder harness attaches to the lapbelt rather than the camlock of a 5pt harness.
See their propaganda video :P here:<ul><li><a href="http://www.hmsmotorsport.com/docs/SchrothASMII.wmv">Video of impact with 4pt harness</a></li></ul>
