Will cryogenic treatment reduce cracking on cross-drilled rotors? Braking Qs.
Will cryogenic treatment help? I know that it would generally harden the surface, but that could work against it.
Also, he's asked if there is a technique that he should use to reduce heat build up in his rotors. My only (amateur) advice was that he should make an effort to use brakes hard and for the shortest possible period (e.g. don't drag the brake). Any other ideas?
<img src="http://www.dietersmotorsports.com/tech/2002/pics/04-02figure1.jpg">
