Motorsport Discussion Discussion forum for everything racing-related
Track wheels/tires BT: I'd like to get a set for the avant this year. 17's or 18's?
Old Jan 23, 2007 | 08:13 PM
MarkFank's Avatar
Default Track wheels/tires BT: I'd like to get a set for the avant this year. 17's or 18's?
I was looking to pick up some inexpensive wheels like the Flik Justice from Edgeracing for $99. Same price for 17s & 18s. The tire prices for 17s and 18s seem to be within $10-$20 for the same tire. I was thinking of the Yokohama Advan A048.
So, with price being equal, should I go with 245/40-17 or 235/40-18? I've never owned a set of R compounds. Would a 225 width be enough for the track? Do R compunds tend to run wide so would rubbing be a big issue? I have rolled the fenders.
Old Jan 23, 2007 | 10:34 PM
Silver Streakin''s Avatar
Member
I would go with 245/40/17 and on the Flik Lex, which I think are lighter than the Justice.
Old Jan 24, 2007 | 06:29 AM
Pat-SoCal's Avatar
Yup, good tire size... I dunno about the Flik wheel though, but at least they are cheap!
Old Jan 24, 2007 | 06:39 AM
MarkFank's Avatar
Default Yeah, I noticed they were lighter. Here are the size options I am considering
Size % Variance
225/45-17 0.0%
235/45-17 1.4%
235/40-17 -2.3%
245/40-17 -1.0%
225/40-18 0.5%
235/40-18 1.7%
245-35-18 -0.9%
The 245/40-17 are the close to stock diameter and would give the most grip. I definately like the looks of 18s over 17 but for track use I guess I shouldn't care.
There has been come complaint of the finish of the Fliks being cheap and some paint peeling, but I'll be using them 4-5 times a year so it's not a big deal.
Old Jan 24, 2007 | 10:58 AM
Alpha7's Avatar
Junior Member
Spacers are required w/ the Justice if you run a BBK. at least over 993TT calipers on an S4.
Old Jan 24, 2007 | 11:20 AM
MarkFank's Avatar
Default I have the 4 pot Alcons w/ 332 mm rotors. The stock 17" avus wheels fit over them.
I emailed edgeracing to see if the FTDs or the Lex will fit.
APD's Avatar
APD
Default No rubbing issues with 245/40-17?
Both TireRack and Edge Racing recommended 235/40-17 when asked about upsizing from 225/45-17.
I was ready to pull the trigger on Flik Ftds in 17x8 with 235/40-17 RT-615s until I read this.
Would 245/45-17s also work?
Old Jan 24, 2007 | 11:40 AM
Member
I think you answered your own questions/complaints. I wish RA1s came in 245/40/17
 Pouria Savadkouei
 Michael S. Palmer
MarkFank's Avatar
Default 245/45-17 definately would NOT work.
When calculating plus sizing on the tires, you have to consider the width and the overall diameter.
A 245/40-17 is wider but the overll diameter is about 1% shorter or 1/3" shorter. Generally the rubbing issues on the B5 S4 comes from a height issue. If you have rolled the fenders, this should not even be an issue.
A 245/45-17 will be 2.8% taller or about 3/4" taller. You will defiantely be rubbing.
I had rubbing issues with a 235/40-18 tire (1.7% taller) but not with 245/35-18 tires (1% smaller).
Old Jan 24, 2007 | 11:47 AM
APD's Avatar
APD
Ditto for RT-615s
