Motorsport Discussion Discussion forum for everything racing-related
Q: raising height on coilovers = increasing spring rate? It's more compressed, right?
Old Jan 29, 2007 | 07:50 PM
laissezfaire's Avatar
Old Jan 29, 2007 | 08:12 PM
D all over's Avatar
Member
Default A: You mean lowering, not raising, right? B: A linear spring has got x spring rate whether it's got
2 lbs on it or 900 lbs squishing it down. A progressive rate spring is another matter.
Old Jan 29, 2007 | 08:20 PM
no, I mean raising, e.g. pushing the spring up. progressive.
Old Jan 29, 2007 | 08:42 PM
D all over's Avatar
Member
Wait, so you mean compressing the spring on the shock without changing ride hieght?
Old Jan 31, 2007 | 05:43 AM
Potomac-Greg's Avatar
Default No, no, no! I went through this recently. You're just changing the spring perch height.
The spring rate does not change at all, and you are not compressing the spring (when you think about it, that would be impossible).
The spring sits on a perch that is threaded on a shaft that is attached to the lower control arm(s); and the top of the spring is seated against the car's body. The perch is on a threaded vertical shaft, and as you spin it, it rides up/down the shaft, and the spring rides up/down with it, pushing the body up or down.
Old Jan 31, 2007 | 06:12 PM
Default I hear you... but on a progressive spring, if the top is fixed, doesn't it change just a bit?
probably not, the more I think of it.
Old Feb 1, 2007 | 06:09 AM
Default Why would it? If you want to get scientific, Earth's gravity is less at higher altitudes, so...
... when you push the body up an inch, it weighs less (probably lightened by the weight of a gnat's wing) and that would lighten the load on the spring!
I had this debate last year, and we all ended up laughing. If you were literally compressing the spring, that would mean that you had a fixed structure connecting the top and the bottom of the spring, which would mean that you would have no rebound.
Old Feb 1, 2007 | 04:40 PM
I get it now. danke sch?n!
 Pouria Savadkouei
 Michael S. Palmer
S4Rules
16
Jan 28, 2008 03:01 PM
Tomasz@Startup
Suspension Tuning Discussion
Jul 18, 2005 09:34 AM
AZSantorin
Audi Original "S" Cars
Aug 24, 2004 07:26 AM
NeS4atu
Apr 6, 2002 07:30 PM
J.R.
Wheels & Tires Discussion
Sep 4, 1999 05:13 PM
