Yellow Malfunction Check Light - Open Ventilation Valve?
Old Jan 21, 2001 | 08:30 PM
add5knots's Avatar
New Member
Default Yellow Malfunction Check Light - Open Ventilation Valve?
Hello everyone,
I'm getting a fault which reads "Tank Ventilation Valve Open". I thought maybe my gas cap, but its always on tight. I'll reset the light, but I get the fault again. I have no clue how and where to fix it. Any ideas? Please help.
Thanks,
JA (98 A4 2.8 5v)
Old Jan 21, 2001 | 08:36 PM
Clark@turbo5.com's Avatar
Junior Member
Default Answer inside.
A few things can cause this: A loose gas cap or a leaking hose.
My car had this error. I found a loose hose clamp near the Air box. The Evap purge valve is located above the air box. It's a black electric pump with several hose leading to it. If one of those lines is leaking it can cause that code. Those metal spring clamps can come loose. I replaced mine with standard hose clamps. Problem solved.
Hope this helps.
Clark
Old Jan 21, 2001 | 11:07 PM
The Bald Marmot's Avatar
Junior Member
Default At least it doesnt look like this:
<img src="http://nutt3r.hypermart.net/a/asgoodasdeads.jpg"
amsnooze
Dec 9, 2017 04:24 PM
Rick 601
Aug 15, 2007 09:41 AM
BLAZNA420
Apr 26, 2005 12:27 PM
tragopan86
Mar 18, 2003 01:26 PM
Lloyd of the Rings
Sep 5, 2001 09:25 AM
