Help! How do I attach front licscence plate without drilling holes into bumper? I got pulled over by a facsist cop....
Old Dec 23, 1998 | 09:29 PM
Jake
Guest
Posts: n/a
Default Help! How do I attach front licscence plate without drilling holes into bumper? I got pulled over by a facsist cop....
<p>I just got pulled over by some facsist cop in L.A. He gave me a fix-it ticket for having no front license plate, having too dark of a tint on my windows, and having clear taillights. The taillights aren't a problem because I'll just replace them when I bring the car into the police station then change them back again. The tint is unfortunate (and expensive) to get rid of, but I can deal. But I will not drill holes into my front bumper and ruin the look of the spoiler! Any ideas on how to trick the cops and fasten it temporarily, and then take the damned thing off?<br>I was thinking along the lines of suction cups.<p>Please help!<p><br>
Old Dec 23, 1998 | 09:48 PM
ned
Guest
Posts: n/a
Default Re: Help! How do I attach front licscence plate without drilling holes into bumper? I got pulled over by a facsist cop....
Stock bumper? if it is, get a license plate frame that has two perpendicular extensions. take out the center grill peice on the lower part of the bumper, and drill the screws in from underneath so they are not visible. The cheaper and easier way would be velcro, however if i has a strong adhesive it may ruin the paint, and if it doesnt, the plate may fall off. try what i said the first time.
Old Dec 23, 1998 | 09:52 PM
JT
Guest
Posts: n/a
I think I'd try the Velcro route!
Old Dec 24, 1998 | 07:02 AM
Jay Cole
Guest
Posts: n/a
Default Affix to inside of windshield, passenger side...
Or you might try using Marine grade silicon sealer/adheasive. Bend the plate to match the curvature of the front bumper and find a license plate frame which will flex and glue the baby onto the bumper. This will get you thru the inspection. The sealer peals off pretty easily, then stick the plate behind the windshield.<p><br>dark tint in LA is just asking to be hassled repeatedly. you look like a thug.<p>btw, it's really not that cool anymore.
Old Dec 24, 1998 | 07:22 AM
Jason M.
Guest
Posts: n/a
I feel for you, I got a ticket about a month ago for tinted windows and the front plate..<p>This is what I'm going to do:<p>Get suction cups, glue them to the back of the plate. Get a license plate frame (dealer one will do) and glue that on to the plate as well (you can use silicon for this). Get two screws that fit into the top mounting holes of the frame/plate and saw off the threads (with a dremel or something) and glue the heads onto the plate, so they look like they're screwed in. Next attach the plate to the front bumper and position it so that it appears the screws go into the bumper..<p>HTH,<p>Jason<br>
Old Dec 24, 1998 | 07:30 AM
Paul B
Guest
Posts: n/a
Default Re: This wouldn't meet the legal requirements
I recall someone posting the CA code for plates at it has a hight limit, so putting it in the windshield probably would not pass the inspection.<p>However, mounting it to the grill temporary might work.<p>Paul
Old Dec 24, 1998 | 07:32 AM
Paul N
Guest
Posts: n/a
Default Re: Attach it to the grill.
Try attaching it to the grill with wire ties. This might pass the inspection and be easy to remove!<p>Paul
Old Dec 24, 1998 | 07:34 AM
Christian J. Long
Guest
Posts: n/a
Default DO NOT DRILL INTO YOU FRONT BUMPER....
DO NOT DRILL INTO YOU FRONT BUMPER! You do not want to scar this car for life! Do as Ned says, and attach it from the underside of the lower grill. Check out my quick drawing I made.<p>One good thing about living in FL, no front plates!<p>Christian J. Long
 Michael S. Palmer
Old Dec 24, 1998 | 11:56 AM
Tony
Guest
Posts: n/a
I used 3M heavy duty VELCRO - 2 strips - then remove. Worked great!
Old Dec 25, 1998 | 09:41 PM
Nguyen
Guest
Posts: n/a
You have clear tail lights? YUCk!
mal441
Q3 Discussion
Jul 19, 2018 07:08 PM
AudiEnthuz
36
May 4, 2007 07:22 PM
diz420
Oct 24, 2006 01:10 PM
Youdaman
22
May 7, 2006 09:44 AM
