Red dome light a la A6 - instructions online
Old Dec 20, 1998 | 10:58 PM
stanj
Guest
Posts: n/a
Default Red dome light a la A6 - instructions online
Ever since driving my dad's new A6, I wanted it. I wanted to see my hand when touching the radio when driving at night. Wanted to just barely see things around me. To be able to find the sunroof switch or the map lights in darkness. This LED based light will illuminate the area directly below the dome light. No visible changes on the interior lighting will be performed. All work can be done in the comfort of your home, short of removing and re-installing the lamp unit of course.<p>May not be to everybody's liking, but it's online now. Takes about 1 hour and costs about $3.<p>- Stan<br><ul><li><a href="http://rescomp.stanford.edu/~stanj/Audi/Dome/index.html">Red dome light instructions</a></li></ul>
Old Dec 21, 1998 | 09:13 AM
JT
Guest
Posts: n/a
Stan, you really are incredible! Geesh!
Old Dec 21, 1998 | 09:54 AM
stevebrown
Guest
Posts: n/a
Default Stan...about the LED
Was really interested in trying this out, so I hit Radio Shack at lunch and found the following:<p>In the 5mm LED side (not JUMBO 10mm), you can get 3000MCD which doesn't say super bright or even bright on the package I have (part 276-307) or you can get 2000 MCD (RSU 11938529...possibly discontinued) all others are less bright than these (800, 500, 10...MCD)<p>I went ahead and got the 3000MCD LED and will try it tonight or tomorrow night...<p>steve
Old Dec 21, 1998 | 10:13 AM
stanj
Guest
Posts: n/a
That's the right one - 3000mcd
Old Dec 21, 1998 | 01:37 PM
RobS
Guest
Posts: n/a
Default Going home tonight and doing the install........
Thanks, I've been wanting to do this for some time. I can never find the cup holders at night.<p>RobS<br>98 Laser Red 1.8T QMS Neuspeed
Old Dec 21, 1998 | 05:42 PM
Tom Halter
Guest
Posts: n/a
Default Is this standard on all A6s?
I gotta swing by the local dealer and check this out in person before I install it in my car.
Old Dec 21, 1998 | 05:44 PM
Rich Quinlan
Guest
Posts: n/a
Default Did it!! looks good! (more) and a question for ya, stan..
I could only get the 2000mcd units, so I think I'll put another one next to the first...<p>Will I have to add another resistor? I used a 100ohm resistor on mine, since I got the dimmer unit. And if I need to add a resistor, I wire it in series, or parallel?<p>Thanks...<p>Rich Quinlan<ul><li><a href="http://home.att.net/~richquinlan">Quinland</a></li></ul>
Old Dec 21, 1998 | 07:18 PM
stevebrown
Guest
Posts: n/a
Everyone interested in this mod go above, look for new post about red lighting!!!IMPORTANT!
 Michael S. Palmer
Old Dec 21, 1998 | 07:42 PM
stanj
Guest
Posts: n/a
Yep, except the A6 has it &quot;cleaner&quot;
Old Dec 21, 1998 | 07:46 PM
stanj
Guest
Posts: n/a
Default Some info...
Wow, how impressive, so many responses! I bet not as many people are cutting their fog light wires today :-)<p>My web page has info on how to compute the minimum resistor. If you add another LED in PARALLEL, you need to compute the 2nd resistor anew, as if nothing ever happened, leaving the 1st in place. If you add a second LED and want it all driven by the same resistor, you need to (a) take the smaller LED voltage of the both for the computation, and add both LED currents (IL) in the computation.<p>I'd stick with one LED, tho, makes life simpler...<p>- Stan<br>
