Help! I slid into a curb this morning and cracked my rim!
Old Dec 21, 1998 | 06:06 AM
Steve A
Guest
Posts: n/a
Default Help! I slid into a curb this morning and cracked my rim!
This morning on the way to work, i slid around a corner and cracked my right rear rim on a curb. It was one of those things: the minute i realized i gave too much gas and was sliding on ice, it was too late! I'm sure i'm not the first person this has happened to, what have others done? How much is a new rim? Any leads on buying them second hand? They are the factory 2.8 alloys. <p>Also, should i be concerned about other damage? The impact was strong enough to break 4 " of the "little lip" off, could the entire rim be bent? I hope there is still air in the tire when i leave work: it isn't supposed to get above 10 degrees today! A tad chilly for changing a tire!<p>Let this be a reminder: Quattro or not, on ice there is no grip!<p>Any comments will be appreciated. Thanks.
Old Dec 21, 1998 | 06:33 AM
randall
Guest
Posts: n/a
Default suggestions:
1/ Steve @ ronal should have used a4 rims.<p>2/ there are places that repair rims. The re-true, etc. i have done this at $100CDN a crack. (i had $300 rims, so it was worth it)<p>3/ HAVE YOUR ALIGNMENT CHECKED. I did about what u did in a laser/talon. This actually bent an "A" arm, requiring replacement, and realignment, and i was only going about 20KPH!!<p>4/ if cost is not an issue, swing into the dealership. I am sure they will check everything, give u a loaner (JIM H?) etc<p>hope this helps<p>1996 a4 2.8 qm
Old Dec 21, 1998 | 06:35 AM
Gary @ Ronal
Guest
Posts: n/a
Default Sorry-OEM available.
However,I do have single's with and without tires.Which style do you have, 5 or 7spoke. 800-899-1212, Gary.
Josh
Guest
Posts: n/a
Gary from Ronal has 5-spoke and 7-spoke for sale; you can find him in the Wheel &amp; Tire forum
sTTay down
Apr 17, 2006 05:33 PM
Tip Trippin
Feb 2, 2005 02:52 PM
DoubleA6
NY / NJ / CT Discussion
Mar 12, 2004 07:15 AM
Vicarious
Feb 22, 2003 09:01 AM
Miles
Wheels & Tires Discussion
Apr 26, 1999 06:09 AM
