breather tube broken, could it cause misfires ?
99 Audi 1.8t had random misfire in cylinder 4 changer coil and plug still the same, went to change pcv valve and found destroyed breather tube . Come led this be the cause?
Hi Lando,
Positive. I vividly remember going mad about misfires and jerks when I pulled off the gas a few years ago. The stealership kept my car for two weeks for diagnosis and charged Eur 1,200 for such and such tests (it was all b*****it). They wanted to replace the ECU and the turbo next, but while it was there I came across a post here and told them to just replace the breather tube (which was broken) and the car started running like a champ again. The real cost was something like Eur 26 (6 for the spare, and 20 for the labour), sighs!
So be in no doubt.
Best,
Robertsons
So be in no doubt.
Best,
Robertsons
Yes - I just changed the crankcase breather last night. part #06A103213F and a pain to get at under the inlet manifold. If that's the same one you are talking about, you need an 'O' ring (N90467301) and a replaced the retaining clip (037121142A). There's a littler PCV valve (035103245G) which I replaced as i had to pull it out to get to the breather pipe. Engine runs smooth again now.
acasee11
07-13-2013 03:01 PM
Auditoy01
05-28-2011 11:12 AM
[ej257]
06-02-2003 01:06 PM
