98' 2.8 30v Headgaskets (rumor has it they dont fail)
Old 09-15-2007, 01:10 PM
New Member
Boosted_4cyl's Avatar
Default 98' 2.8 30v Headgaskets (rumor has it they dont fail)
How common is it for them to fail? I have 135k/mi always run 90+ octane and enjoy a spirited drive on occasion. Now i have an overheating problem, and I am praying its not the headgaskets, I just really dont want to do them, I wast getting ready to list the car for sale in order to buy a turbo a4 with less miles.
Old 09-15-2007, 03:37 PM
Banned
4Rings::G2 boosted::'s Avatar
it's not the headgaskets. Probably your t-stat is going bad.
Old 09-15-2007, 04:46 PM
New Member
Default Re: it's not the headgaskets. Probably your t-stat is going bad.
It starts to overheat and boil over in the tank. I shut it down and crack open the air vent on the coolant tube under the front of the intake and nothing but steam comes out. Upper rad hose gets warm but not too hot and the intake itself stays cool. I dont think a cooling flush has ever been done on the car. Will audi antifreeze boil after 10 years of use? or would a thermostat be more likely. Im just hoping its not not the headgaskets. I always run 91+ octane
also when its hot and i squeeze the rad hoses they are not super tight like they would be if they were crammed with pressure from leaking headgaskets.
no leaks, runs great.
Thanks a lot for your help
Old 09-15-2007, 08:57 PM
New Member
Tr00p3r's Avatar
I got 327,000 on original gaskets
Old 09-16-2007, 09:59 AM
Tech Guru
4Driver4's Avatar
Keep driving it and it will be the headgaskets...and the heads and the block. Replace the t-stat.
Old 09-16-2007, 05:01 PM
Member
77'911's Avatar
Default a comment....
Its probably coming time for a new rad, and a few other coolant system components(sensors, fan, t-stat). I found ours was leaking and loosing some of its cooling efficiency around 58k(changed it out). Head gasket issues are somewhat rare on these motors but anything is possible with Audi. If you let the car over heat more then once, you might be replacing headgaskets and installing remaned head. These engines do not like to be over heated at all. It also makes a difference if the car had regular coolant changes.
Old 09-17-2007, 04:38 PM
Member
S4_Cinci (I S'edTFA)'s Avatar
Your radiator likely has blocked passages, since coolant has never been changed.
Old 09-17-2007, 07:03 PM
New Member
Pulled the thermostat out and I cant even pry it open with a screwdriver. Thanks a lot everybody!
Old 09-18-2007, 07:25 AM
Member
...unless it is something really simple like a bad t-stat... ;^P
Old 09-23-2007, 09:15 PM
mezonesxbox's Avatar
maybe your waterpump is dead.. like shattered impeller
coheed2.8
01-26-2011 10:43 AM
sapsecurity01
A4 (B7 Platform) Discussion
04-15-2009 01:11 PM
B-Ham S6
01-31-2007 06:54 PM
Luis A
09-22-2005 05:54 PM
victor army
11
11-15-2004 01:01 AM
Quick Reply: 98' 2.8 30v Headgaskets (rumor has it they dont fail)
